When I record on the TM F3/5 the picture quality is good but for some reason the audio drops. On the recording there is no audio and if you view the channel there is no audio. I have loaded the latest patch and still having the same problem. Can anybody please advise me on what I might be able to do to rectify the problem. Thanks in anticipation.
TM F3 / 5 Recording Problem
Thank you for the response. I have only recently got the box and it was working fine on the recording side. I only have FTA channels and not had this problem before. I have installed the latest patch 114p 24 03 2014 to see if this cured the problem and it didnt. I have checked the audio volume, there is nothing. Once you stop recording a channel you then have to change from the prog you were trying to record to another in order to get the sound back.
I have done a factory reset and reloaded everything and still the same. It may be that I have reloaded the problem with the files I am using. Hopes this makes it a little clearer. Once again thank you in anticipation.Comment
I dont think it matters if you buy off Ebay or pay more from a Sat TV shop there are no Clones of this receiver about so any bought must be Genuine.
When you say you have issues with the sound which satellite are you recording from and which FTA channels
Hi, I have F3/5 and 5402 boxes and have the same problem on the F3/5, the 5402 is better at recording but still awkward, on the F3/5, if you flick up a channel ten back the audio comes back on, then don't forget to watch the recording on the same channel as the recording, complicated isn't it!!Comment
Hi Olddog, Have you seen this thread,could be the solution to your problem: http://www.digital-kaos.co.uk/forums...l-list-417703/ Also make sure you have the latest patch Cheers MarkHi, I have F3/5 and 5402 boxes and have the same problem on the F3/5, the 5402 is better at recording but still awkward, on the F3/5, if you flick up a channel ten back the audio comes back on, then don't forget to watch the recording on the same channel as the recording, complicated isn't it!!Comment
