technomate 5400ci+super patch
  • willie1970
    • 5
    need new patch for digi tv
  • wooper
    • 460
    Try this
    For Technomates Series 1000, 3000, 5200, 5300, 5400, 5600, 6800, 6900 and Super
    RCS Digi TV (2011) new 01 Keys (0.8?/1.0?W)
    • willie1970
      • 5
      still probs
      many thanks for the file but sorry to say i am still getting scrambled channel comes up i have a tm 5400ci + usb super with patch 1.29p and cant get anything to open
      hope someone can help me
      thanks so much
      • dick b
        • Jun 2009
        • 2462
        I think you need patch xxx dated 15/07/09 its in the threads some where will look for it and edit when found
        sorry that patch was for tm1000
        • wooper
          • 460
          Sorry, me being thick.
          I posted the softcam, do'h.
          Try this patch. Thanks to magic, etc.
          • willie1970
            • 5
            thanks will now try it so will hope thanks mate
            oh is there ment to be 1 channel that u ment to go on for it to update keys on ?
            again so many thanks
            • willie1970
              • 5
              is that all ment to do is just put the patch on receiver what channels do it do does it do eg: cartoon network minimax movies24 ect ? it does seem to do hustler tv and the romantica but thats seems to be it
              sorry to be a pain
              many thanks
              really do need some help so much to get channels to work any help please now put softcam in dated 29-7-2009
              with tm-5400 ci+ usb super 1.29p when go in to system info i look in cas menu and all keys are there
              when i look in bliss all keys are there but top line says off ? all i get is scrambled channel i now been trying this for 2 days with still no pic any help please i`m going bald pulling my hair out
              so many thanks
              • dick b
                • Jun 2009
                • 2462
                sorry to be a pain
                many thanks
                so many thanks
                sorry if this is a bit late and you may be sorted now.
                are sure you are on the right sat as hustler opens on Sirius.
                The channels you are after are on Thor @ 1West
                • coin
                  • Sep 2009
                  • 9
                  coin-newbie
                  Hi all I would also like the new patch for the Technomate TM-5400 CI+USB.Thankyou.
                  • Manic01
                    • 5117
                    Patch does not open digi tv on auto update anymore, just load new softcam and make sure digi tv is turned off in options-digit tv-OFF-exit and save.
                    • coin
                      • Sep 2009
                      • 9
                      coin newbi
                      Hi thanks for reply.Softcam??.Can you please explain as I am a complete newbi.I was thinking of buying a programmer and fun cards,will these work and is this what you mean by softcam.Thankyou again.
                      • benny/9
                        • 1964
                        save your money mate you dont need a a fun card
                        or programmer just load the latest dated
                        tm softcam the same way as patching.
                        the softcam is a key file with all the latest
                        known keys added. and you can load it in seconds
                        with a memory stick, you will find the tm softcams
                        posted in red at the top of the technomate section
                        Please Read Carefully!
                        • coin
                          • Sep 2009
                          • 9
                          coin newbie
                          Hi,all.I downloaded the patch for my TM-5400 CI+USB Super and have installed the patch.I check in bliss all the keys are there but the top line says OFF so what do I do now.Do I also need a cam/card installed as well.Please help.Thankyou all.
                          • benny/9
                            • 1964
                            just leave the biss panel setting as it show's
                            if any channel does'nt open it could require
                            a new key, when you have the keys you go
                            to the channel you want to enter keys for and
                            on the remote press 8280 and the biss key panel
                            will open, you now scroll down the panel and find
                            a empty key line [all zero's on it] and you now enter
                            the key for the channel and then exit and the channel
                            will open, with biss or dcw keys you have to go to every
                            channel in turn and enter the keys this way for every channel
                            and if you keep a note of the line the channel uses when the key
                            changes you can just over write the key with the new key and you
                            keep the channels useing the same key line
                            • coin
                              • Sep 2009
                              • 9
                              coin newbie
                              Hi,thanks for your reply.as I said I installed the up to date patch and all the keys are there apart from the top line which says off and no channels are open.Do I need to instal a cas as well as this patch.Thanks.
