Hi Guys! Ive been having prblems with my thor 1 West channnels the last few days. Ive los quite a few channels and the others that are up tend to freeze a lot and could be clear sometimes. Ive scanned, checked all the LNB connections on the box making sure its secure. Got some joy as some of the channels came on but lost them again and the others still patchy. The free channels and sirius channels are fine. Any ideas? Thx
Technomate Softcam Updates
This topic is closed.
Dish alignment
What has the weather been like? Bad weather will cause bad reception or it could be you have a signal strength problem from wrong alignment. Maybe the dish needs a fine tweek. What is your signal strength for Thor? It needs to be 50%+ should be getting around the 80% region. Try moving your dish slightly.Hi Guys! Ive been having prblems with my thor 1 West channnels the last few days. Ive los quite a few channels and the others that are up tend to freeze a lot and could be clear sometimes. Ive scanned, checked all the LNB connections on the box making sure its secure. Got some joy as some of the channels came on but lost them again and the others still patchy. The free channels and sirius channels are fine. Any ideas? Thx
RegardsComment
for all the technomate models except the tm 3000 models
you use the v187 loader the tm 3000 uses it's own loader panel
both are on the forum, if your technomate has a usb port then
the easiest way is to load the softcam with a memory stick
the tm softcam is for use on all the modelsPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
