TM 1500 update for digi tv
  • spun1965
    • 6
    Help please - loaded the 2nd softcam update last night and used the darkman loader to transfer the file, i had switched off the AU on digi in options first and channels still won't clear. Shall i re load everything and start again or have i missed something.
  • technomate
    • 64
    REINSTALL SOFTCAM I HAVE POSTED YESTERDAY 2ND DIGI.
    All Files posted are for educational purposes only
    ALL MEMBERS PLEASE READ & FOLLOW RULES .
    • jona star
      help, where can i find the latest technomate key?
      • dick b
        • Jun 2009
        • 2462
        latest digi key posted in the sticky section was working 1/2 an hour ago.
        • dick b
          • Jun 2009
          • 2462
          I have just checked again and digi tv is not down using this softcam you can always open the unzipped file using notepad and put keys in manually (its ident 2011)the last one.
          • spun1965
            • 6
            I have just tried again using the softcam above with no joy.
            When i press connect it says 3.04 version detected, i press install and it says writing and the display on the TM goes from 0 to 100 and then loader says finished.
            I have gone into system info from menu and then into CAS menu and it is all blank in the boxes at the top i doesn't say nagravision and digi tv isn't up, also no numbers in any of the boxes. I have only ever used the patch before but think i had a look in there once and all the numbers were in there.
            If i am doing something wrong please let me know or show me the thread to explain how to manually input the numbers. thanks in advance Spun.
            • dick b
              • Jun 2009
              • 2462
              dont forget that you must press the "keys"tab at the top of the loader when putting softcam in.that sounds like your problem.
              • spun1965
                • 6
                Thanks for everybody's patience - i have tried again with the latest softcam afterr checking the tab was on keys with no joy. i have looked at the keys in the file but don't know how to manually input what numbers on what lines. i have gone into the cas menu and there are 4 ident boxes and 4 sets of boxes to input numbers or letters. Please help as the next step is a 2 pound lump hammer. Ha Ha.
                Spun
                • spun1965
                  • 6
                  All sorted - big thanks to dick b for all his help.
                  Spun
