Technomate: Thor help
  • benny/9
    • 1964
    #16
    Originally posted by spearmintone
    The null modem cable arrived; used the darkman loader etc, loaded the patch then the softcam, still nothing!!
    Maybe it's the box. Should I wait until New Year and send the bugger back?
    I don't know what else to do.
    turn on press menu and go to system information>ok
    and on the second line down s/w does it show the
    patch loaded? if yes exit and go back in the receiver
    menu and go to options>ok and make sure the A/U for
    digi-tv is set to off. if you hav'nt done it already
    Please Read Carefully!
    • sattboy
      • Mar 2009
      • 84
      #17
      hi m8
      first off did you make sure that the patch and softcam are unzipped? also did you put reciever into standby before u uploaded from pc.
      • spearmintone
        • 11
        #18
        Thanks. Yes to both of the above...
        • sattboy
          • Mar 2009
          • 84
          #19
          right m8 a lot of people on these forums keep saying to make sure DIDI TV AU IS OFF from the time i have had my technomate and done softcams and patch i have always left it on never ever had a problem loading cams you may have a duff box but i doubt it.rest your box back to facory default and start afresh then do it the way i suggested in previous thread.good luck this time and merry xmas
          • dick b
            • Jun 2009
            • 2462
            #20
            try this patch and softcam
            • Manic01
              • 5117
              #21
              If you ahve a patch loaded which had Digi tv auto update on it the option needs turning off as it inserts incorrect keys.
              • pete1dillon
                • 4
                #22
                hi also having problems. Ive updated keys before and thought it was straight forward but when i went to do it recently via usb the keys arent there when i put in usb. I unzip files as usual but they just dont seem to be there. Anyone have same problems or any ideas?
                • spearmintone
                  • 11
                  #23
                  I hope you have more luck than me, Mate!
                  • Manic01
                    • 5117
                    #24
                    For keys to show via usb receiver must be patched and the patch must be turned on.
                    • Manic01
                      • 5117
                      #25
                      hi m8
                      No need to be in standby.
                      • dazzaman1970
                        newbee
                        hi guys, just trying to get my head around all this... feel like a complete loser as i don t have a clue where to start, was recommended to buy a tm 5400 usb as am wanting to watch the footy. any help greatly appreciated
                        • dick b
                          • Jun 2009
                          • 2462
                          #27
                          I"d start by reading the "stickies" above the normal threads then ask any specific questions and some one will help.to get the most out of any box you need to motorise it.
