Hi,sorry if question silly, I have found out that my receiver doesnt get any signal quality (0%) on Horizontal polarization but good signal on the Vertical (about 94%).....what could be?Just my nipper playing football with my dish?
Please help no H polarization
no horizontal
check the lnb settings in the menu,s to make sure its not set to vertical. i think it should be h/v or auto also check your f-connector and make sure there are no new kinks or damage to the cable. if everything indoors checks out then its either the cable or lnb outside . just try to eliminate each possible fault until you find it.DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
