TM500/600 UR Image 11-10-09
  • Manic01
    • 5117
    fixed jittering
    change default remote speed
    remove problem channel list
    ECM menu on bookmark button
    update firmware options from LAN menu
  • dick b
    • Jun 2009
    • 2462
    can I enter softcam keys on the TM500 useing tcc if yes how to go about it, latest ur image installed.
    • .: JaCkPoT :.
      Retired Sat TV Addict
      • Aug 2008
      • 5611
      Press the red button and the latest keys will be automatically downloaded from the UR server.
      ___________________
      In the good old days, I had
      DM800s HD
      Openbox S10
      TM500
      DM500s
      90cm FortecStar dish
      Maxx 110cm Dish
      Technomate 2300 Motors
      • dick b
        • Jun 2009
        • 2462
        box is not connected to internet
        • bugaloo41
          • 1598
          Dick you can input manually.
          1) press yellow button;
          2) start up tuxbox commander:
          3) navigate to var/keys folder;
          4) scroll to and highlight softcam.key;
          5) press 4;
          6) you should now be able to edit with the remote.
          Ca you not just rig up to the net though mate a lot easier?
          • .: JaCkPoT :.
            • Aug 2008
            • 5611
            Or search for latest dreambox keys, then FTP to /var/keys
            ___________________
            DM800s HD
            Openbox S10
            TM500
            DM500s
            Maxx 110cm Dish
            • dick b
              • Jun 2009
              • 2462
              thanks "Bugaloo"&"jackpot" I"m a bit lost when it comes to IT skills.I got the tm500 to play with and will try the manual method(it doesnt have to be easy I just enjoy trying to do it).I do have internet its not broadband though just dial up with an internal modem, but the tower has an ethernet port so I"ve got a cable on order and will see if that works.This is just a rig I"ve set up in the bedroom so I can play without annoying the rest of the family.
              • hort_ma
                • Feb 2010
                thanks ......
                • dick b
                  • Jun 2009
                  • 2462
                  5) press 4;
                  sorry mate pressed yellow brought up plugin menu but only got teletext on it nothing else,do I have the right image installed (UR 14/10/09)
                  • Manic01
                    • 5117
                    Load a newer image Dick. It's def on yellow button plugins. 4th down for me.
                    • C_S_B
                      • Feb 2010
                      • 56
                      Hi Dick cancel the network cable m8, what you need is a null modem cable. If you want to use the network adapter on your PC to connect to your STB you will need a cross-over cable. Something you will never use again. In allmost all cases a null modem cable (cross-over serial) will serve you better now and in the future.
                      Download any files via your dial up to your PC then transfer to STB via null modem cable.
                      csb
                      "The Transmission of Documents via Telephone Wires is Possible in Principle, but the Apparatus Required is so Expensive that it will never become a Practical Proposition" Dennis Gabor 1962
                      Hungarian-born electrical engineer who won the Nobel Prize for Physics in 1971
                      • dick b
                        • Jun 2009
                        • 2462
                        I"ve already tried to load via tcc 7.1 without success as you say I could not do it with the ethernet cable either and ur image dated 20-01-10 still had the plug in I needed missing so its back to finding an image with it on I"ll download some more and try them.
                        thanks dick b
                        • C_S_B
                          • Feb 2010
                          • 56
                          thanks dick b
                          Hi, D
                          slight mis, you wont be able to with a Standard ethernet cable. See attached pic. A crossover ethernet will be fine in a stand alone PC to STB with a modem. Your PC (windows 95b upwards) will act as DHCP server and give your stb an ip address for communication.
                          You could use a hub/switch to connect the 2, this will require 2 normal ethernet cables but be doing the same job as a cross over.
                          You could use a router (dosen't need to be attached to internet) this way the router will do the job of DHCP server, for addressing, and you can plug in/out your stb and PC at will. This would in most cases let you network other devices as well. This way you can ftp (i really like filezilla ftp client) via your new LAN.
                          This will require a router, 2 ethernet cables. But possibly a crossover ethernet cable if the router dosen't have a crossover port.
                          Its money in the end mate, crossover ethernet (home made or new) being the cheapest.
                          But be carefull if stripping up a UTP cable the sleeving is very thin, use your finger nails not a knife or pliers.
                          csb
                          • C_S_B
                            • Feb 2010
                            • 56
                            Oops. Forgot
                            UK and Europe use 568b wiring Americans use 568a. Cross over happens to be one of each wiring pattern on either end.
                            csb
                            • C_S_B
                              • Feb 2010
                              • 56
                              Oops 2
                              with a router you wont need a crossover cable just one normal ethernet for each device.
