tm 600 streaming
  • eattheliving
    • 331
    tm 600 streaming
    hi all, got my tm 600 hooked up and upgraded the image to the latest ur. my problem is that i cannot get my pc to video stream to the box. i have dloaded vlc, set the ip on vlc to the router ip. ran the media player on the box but am getting an error message telling me that it cannot connect to the pc,
    any ideas anyone....help please.
  • eattheliving
    • 331
    come on guy's need help please. I have just re done the image via the tm control centre so i know that the pc is set to the box, it's just the streaming via vlc i can't figure out. also what format do the movies have to be to play them from a usb stick?
    cheers
    • C_S_B
      • Feb 2010
      • 56
      Hi m8,
      are you trying to stream from your tm so you can watch on pc, or the other way round?
      To your PC is easy, haven't tried the other way.
      csb
      "The Transmission of Documents via Telephone Wires is Possible in Principle, but the Apparatus Required is so Expensive that it will never become a Practical Proposition" Dennis Gabor 1962
      Hungarian-born electrical engineer who won the Nobel Prize for Physics in 1971
      • eattheliving
        • 331
        Originally posted by C_S_B
        Hi m8,
        csb
        hi C_S_B, pc to tm matey. i have read all the tuts regarding vlc but just can't seem to get a connection.
        • C_S_B
          • Feb 2010
          • 56
          Sorry I couldn't help at the mo. Playing with channel list, but will see what I can find out later.
          good luck
          • eattheliving
            • 331
            good luck
            no probs matey. gonna be tied up this arvo putting my dish up.
            • installer2
              • Feb 2010
              this is difficult to do, have read a bit on other forums, tried a little but no luck, if you manage to get it sorted, please post a how to for others, (me)...
              • eattheliving
                • 331
                certainly will matey. i have enlisted the bro in law who is a network engineer. gonna have a play tomoz, unfortunatley we got carried away with supping the john smiths this afternoon..
                • bugaloo41
                  • 1598
                  eatheliving, hope this may help mate.
                  Just Managed to get XviD streaming to my TM600
                  Install VLC 0.8.6i
                  then create shortcut > right click on shortcut > properties > then add this to target line "--intf wxwin --extraintf=http"
                  e.g mine is now
                  "G:\pvr\VLC.old\VLC\vlc.exe --intf wxwin --extraintf=http"
                  start vlc from that shortcut and go..
                  Settings > Preferences > Input/Codecs > UDP port "change to 8080 and save"
                  Now Load TM webui > Zap > Stream > Settings > Server Settings > Edit
                  and change
                  Server IP Address : to the i.p you are running VLC on. e.g "192.168.1.2"
                  Movie Directory: to the drive letter you want the TM to be able to load files from.
                  Finally with VLC running, Press yellow button on TM and select "VLP (Movieplayer 1.5)
                  then just find file you want to play and select it. will take a while to start/buffer...
                  p.s
                  i found the quality to be quite low when streaming xvid's so i went back into
                  TM webui > Zap > Stream > Settings > Video Settings
                  and clicked on the little pen n paper icon on the avi line and edited
                  Video Rate: 2200
                  if you go much higher then that the video will start glitching.
                  think thats was everything i did...
                  Updates:
                  1) 576x576 and put the bitrate to 3000
                  2) also it wont load any files with spaces in the name, gives me an errors so just change.them.into.dots.avi
                  Kudos goes to ToneDeff for the guide.
                  • eattheliving
                    • 331
                    Install VLC 0.8.6i
                    e.g mine is now
                    and change
                    p.s
                    Video Rate: 2200
                    Updates:
                    thanks bugaloo41, will give it a go matey and report back.
                    just one thing matey where do i get tm webui from?
                    • C_S_B
                      • Feb 2010
                      • 56
                      its the front end when you log in via browser,
                      csb
                      • eattheliving
                        • 331
                        csb
                        hi C_B_S, do you mean the tm control center? up to yet thats the only way i have been able to get anything to my tm box
                        • bugaloo41
                          • 1598
                          must be the web browser mate. log in via the browser and alter your settings.
                          • eattheliving
                            • 331
                            Install VLC 0.8.6i
                            e.g mine is now
                            and change
                            p.s
                            Video Rate: 2200
                            Updates:
                            getting an error mssg. pic has been attaced for your thoughts matey
                            • eattheliving
                              • 331
                              ur not wrong bugaloo. logged in but as you can see i am getting an error mssg whenb i try to edit the vlc target name?
                              it says: the name 'c:Program files (x86)\videoLAN\VLC\vlc.exe --intf wxwin --extraintf=http' specified in the target box is not valid.make sure the path and file name are correct.
                              any ideas mate?
