I'm in scotland near glasgow and have a 88cm motorised dish. Any info is appreciated.
Which satellites can I get ?
Problem with TM600 or hard disk ?
I used an USB drive to connect to the front USB port. Then recorded a program, after that disconnected the drive.
Another day I was watching a program, while receiver was running I connected the USB drive and it said I had to format it ?? -
i had bother when i connected an 80gig drive, after a while i just changed to 16gig memory stick.
if you want to try a a hard drive you might have have to do a fat32 format...follow link below,
How to format external hard drive to FAT32 in Windows
hope this helpsSky+ HD Spiderbox 9000hd TM 5400 ci+ 90cm dish motorisedComment
Ok, I will try this. First time I used the format tool from technomatei had bother when i connected an 80gig drive, after a while i just changed to 16gig memory stick.
hope this helpsComment
You can get most of what`s up there with your size of dish.You can get the Astras @28 deg. E. Hotbird @13 Another Astra @19e thor @1de. W and more. Depends on what youre looking for. You can check out sat. info. @ lyngsat or @ Flysat.Depending on the type of sat. receiver you have, you may be able to open encrypted channels as well . Good luck.Comment
Just a (silly ?) question, what would happen if I chose a satellite out of reach. Would the motor still try to get the satellite and damage anything ? Or would motor just stop after it's reached the most eastern and/or western position it can get too ?You can get most of what`s up there with your size of dish.You can get the Astras @28 deg. E. Hotbird @13 Another Astra @19e thor @1de. W and more. Depends on what youre looking for. You can check out sat. info. @ lyngsat or @ Flysat.Depending on the type of sat. receiver you have, you may be able to open encrypted channels as well . Good luck.Comment
the motor will move to any satellite on your list but wont open all of them, as you may need a bigger dish for better signals.Sky+ HD Spiderbox 9000hd TM 5400 ci+ 90cm dish motorisedComment
You can look on Satellite Finder / Dish Pointing Calculator with Google Maps | DishPointer.com to get an idea of what satellites you can recieve. I think sometimes it's a little off thou in my case. Click on "All available satellites and estimated dish sizes for your location"Comment
and 19.2E and 28.2E Sky, but not sure which others I Can get ?
