It's meant to be a bin file.
Noobs guide to patching your Technomate
patch 1st then soft cam. the patch will overwrite the official technomate software.but be aware softcams are dating very quickly at the moment.Comment
Thanks.Please correct me if i am wrong.i can overwrite not updated technomate software with the newest patch then soft cam.Do i lose channel list?Comment
no you will not lose your channels providing you do not do a factory reset,even then providing you you do a"save as default"( do this twice) you should be able to re-install them
but I"ve found it doesnt always work.you will only need to do a re-set if you find any bugs.
any software you put in either official from tecnomate or 3rd party will simply overwrite whats already there and you can switch back no problem providing you have a copy of the file in your computer.Comment
Can any one help me? I`ve got Technomate TM 3400 Ci+, I try install the patch.
- I downloaded the 3100_3200_3300_3400-P-07-09-2009.zip patch and extracted it
- I downloaded the TM-3000 SeriesV1.1.3.zip loader and extracted it
- I connected my PC using a USB2RS232 and serial null modem cable
- I selected the right port
- I opened the loader and selected the software tab
- I pressed browse and found the extracted patch
- I pressed start button
- Loader shows Transfering... but no action I can disconnect cable, turn off switch on back
no message still transfering... but doesn`t work
Where can i find patches for TM 3400 CI? I found one but when a click on link, it`s blank
screen only. Thank you.Comment
got a question i am on thor 1w channels all work but tv guide say no info on most channels is there a patch or softcam im missing any help please searching though 50 plus channels for the match is a pain
dazComment
HI there’s not tecnomate 500 but for what you require tecnomate 1000 o any of the tecnomate is good for peeking up this channel okComment
. I have just bought technomate 6900 combo super. Can any one please tell me, do i have to load the newest software from technomate prior to load the newest patch
