Will these work on blackhole 1.7.9? Getting my solo2 tomorrow, and this is the bit I'm struggling on we'll so far the rest has been a good read
black hole 1.7.6 cccam ?!
****************************************Originally posted by henninghansenWill try the file
the BH cccam packs will work with every BH image version
on all vu modelsPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
How to cccam for BH 1.7.9 Solo2 ?
first in the folder you will find 4 cam packs take them out
but do not open them just transfer them to the tmp folder with your DCC
close the dcc then with the remote press green then yellow
then on the second line down manual install bh packages>ok
now you can see all the cams you sent to the box with the dcc
now just click>ok on each of them in turn and follow the on screen info
untill you have installed all of them,re boot the box and then when you press
blue you can select and change to which cam you want to use
How to cccame for BH 1.7.9 Solo2 ?
How to cccame for BH 1.7.9 Solo2 ?Comment
ftp the the file into /tmp using filezilla then install via the bh installer(green then yellow). then press blue and start the cam. when you have the cam running get your sea-lion and ftp again into /ect, save and re-start for good measure,regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
Yeah I got on fine, I followed the instructions to the letter... what I didn't realise that you have to upload via FTP your cccam.cfg file into the etc folder to get your cccam line details in there so it will work... That had me stumped for ages!Comment
Guys this is just my personal opinion, but I think the Vix image is better on the new Solo 2, it displays the channels it's on etc, whereas BH didn't, and the Vix image is just easier to setup/navigate if you are a novice enigma 2 user.
Just my 2 cents worth, try whatever image you want :-)Comment
Not sure i understand that Dell mine shows what channel it is on in the display no problem if thats what you mean.
Yup when I flashed it with BH it would only show the folder name m8, ie Entertainment etc, I'm better using Vix so maybe just something in the menu that needed changed ?Comment
Just received my solo2 and currently upgrading to the latest blackhole image. hope the cam works!Comment
