black hole 1.7.6 cccam ?!
  • Aindriu
    • Jan 2013
    • 7
    #46
    Originally posted by benny/9
    first in the folder you will find 4 cam packs take them out
    but do not open them just transfer them to the tmp folder with your DCC
    close the dcc then with the remote press green then yellow
    then on the second line down manual install bh packages>ok
    now you can see all the cams you sent to the box with the dcc
    now just click>ok on each of them in turn and follow the on screen info
    untill you have installed all of them,re boot the box and then when you press
    blue you can select and change to which cam you want to use
    Thanks a million for that! I am building my first two Vu+Duo boxes this weekend
    • Leesaunders
      • May 2011
      just wonted to say thanks for this info as it has heled me aslo
      • cgooding82
        • Feb 2013
        Thanks for the all the info.
        • synologic
          • Feb 2013
          I will try it with BH 1.7.9 today on my Solo2. Hopefully it works otherwise i have to buy a CA module for canaaldigitaal.
          • townjuju
            • Feb 2013
            #50
            Pls guys, how can i setup cccam into blackhole v133, im using dm800 sim2.01 #82
            • septicsmurf
              • Feb 2012
              • 401
              #51
              Sorry mate, you're in the wrong place. This section is for vu+.
              You should ask in the dreambox section.
              • noar23
                • Feb 2013
                CCCam for BH 2.0.01
                Hi, How can I use CCCam for BlackHole-2.0.1 OE 2 (VU+ Solo)? For previous versions I was using tunisiasat-addons-manager_3.0_mipsel, but it does not work anymore due to new python version.
                  #53
                  Yes you most certainly can all the Cams included in the pack will work
                  • billywear
                    • Feb 2013
                    cccam
                    how do i intall and set up ccam on vu solo2 with BH?
                    • mdt
                      • 3034
                      #55
                      using Vucc/filezilla install C**am 2.2.1.ipk into /tmp then install in addons then put cfg in /ect,regards mdt
                      • Roddypiper
                        • Feb 2013
                        • 13
                        #56
                        Hi,
                        After doing as you explained I receive the followning message:
                        Nothing to install.
                        You have to Upload a bh.tgz package in the /tmp directory before to install Addons
                        Please help
                          #57
                          Originally posted by Roddypiper
                          Hi,
                          Nothing to install.
                          You have to Upload a bh.tgx package in the /tmp directory before to install Addons
                          Please help
                          Did you reboot your receiver by chance after ou uploaded the tar.gz files if so they will have been deleted, follow the instructions as benny/9 has stated and they should install fine
                          • Roddypiper
                            • Feb 2013
                            • 13
                            #58
                            sorry, what is a tar.gz file?
                            I put the cccams in the temp folder and get the error msg displayed above.
                            It might help for you to know that I am using BH 1.7.9, do I need to upgrade?
                            • Roddypiper
                              • Feb 2013
                              • 13
                              #59
                              Woohoo! got the cams on there now.
                              Thanks for the info Benny, topman. The only thing I was doing wrong was extracting the files when there was no need. I misread the info (been a long, long day).
                              Again thanks Also to Digicon.
                              dont suppose I can push my luck and ask what I then do to get the full use of these cams?
                              • andy91
                                • 3583
                                #60
                                Thats the part we cant talk about on here hopefully someone can pm you
                                Andy.
