i have a clone vu duo version 3 will not flash through usb nor will flash through vu util will connect to com port in vu util when i click on connect it says fail to open really stuck need some advice thanks
Was it working when you got it?
What version is the box?
Did you load bootloader and if so which one?
Did you load an image?
Did you unzip file before putting on usb?
Did you reboot box after putting bootloader on?
Did you format stick after bootloader and then put image on?
Did you then reboot after image reflash?
Was it working when you got it? no
What version is the box? v3
Did you load bootloader and if so which one? included with image
Did you load an image? not successfully no
Did you unzip file before putting on usb? yes
Did you format stick after bootloader and then put image on? yes still no luck tried 3 other usb and nothing still starting to give up now
I have tried with vu util will open up com connection but wont let me connect through ip it says failed to open after this still not getting anywhere?
When you say will not let you connect through 'ip' you dont mean trying to flash through Ethernet do you as the VU has to ne flashed through a serial port on a PC/laptop
Thanks I have tried this but once I click flash it says fail to open it opens up serial fine then says turn on box which I do then I try connect again and it says failed to open and can't go any further
Also consider that the Clones will not flash via RS232 unless you have a so called hard wired serial port and not the adaptor type as the latter will not work.
