I have had problems with recording since flashing with this image. Many recordings only have a playback time of 2 seconds for some reason although it shows the programme is recording for the whole duration. Anyone else have this issue? Any ideas on a fix?
Recording Issues Vu Duo ViX 2.3 (Linux 3.1.1) 25-12-2011
I'm not sure there in the Public image just yet although it's a very easy process to FTP the drivers to the box then reboot and done. note however that these drivers are only for images running the 3.1.1 kernel as they wont work on older 2.6.x kernel images.Comment
If you do a search for vu duo drivers 02-01-2012 on google and download and extract the file, you should have 3 files which you need to replace with the files in the following directory: lib/modules/3.1.1
Then restart your vu duo and you should be good to go, restarting may take an extra few minutes as mine did so be patient!Comment
VIX 2.3 to VIX 2.2....going back
Am thinking of going back to my older 2.2 version (too many issues with 2.3. My 2.2 was rock solid
and no problems......do i still need to use NEW bootloader?
,its a whole new world from cable
