It could be absolutely anything dish alignment, Cable problem, Motor Problem etc....
tuner issues
Right, installed Catseye bouquets, i can see all the different folders ie sky uk movies, sky uk sports which all work correctly, however when i choose a different satalite ie hotbird 6 and choose sky italia news there are no channels available not even fta, and this is the same with all other satalites. What am i doing wrong ?
are your usals settings correct for your area??? regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
If your Longitude is -2.1926 then in your settings you will see it has a 6 figure combination 000.000. so you enter it as 002.192 in your settings
what i'm going to say had me thinking this
sounds strange but is it worth trying?
on anouther forum a few had the problem
with usuals on the clone duo and one said
he got his working by first setting the tuner
to advanced for diseqc 1.2 setting that up
and numbering all the sats he wanted.
then he change the tuner to simple and possitioner
and typed his long/lat settings in, and after loading a
channel list the motor found every satPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
Thanks Benny/9 will give ur suggestion a go , but before I'm going to try and swap the coaxial cable over just incase iv put them into the wrong ports in the receiver . I have posted this in another forum which just gives a bit more detail about the problem I am having .
Hi guys hope u can help, I have a Motorised dish connected to my duo, an installer did the fitting but couldn't get the tuners to scan so left with just a dish up saying its fully working but need to play around with the settings to get it to work. He says It has been set up using usals.
Settings I have :
Tuner a:
config mode - simple
Mode positioner
Long(entered from satsig)
Lat ( entered from satsig)
Tuner B: set to second cable of Motorised
When auto scanning I was getting no channels so i have tried a simple search on single
28.2 eurobird
diseqc - no
and this picks up all channels expected in the region of 1051
however when I use the settings above for the Motorised dish all I seem to pick up are the standard uk channels and no foreign fta . I installed Catseye bouquets, i can see all the different folders ie sky uk movies, sky uk sports which all work correctly, however when i choose a different satalite ie hotbird 6 and choose sky italia news there are no channels available not even fta, and this is the same with all other satalites. What am i doing wrong ?Comment
If your USALS settings are not correct and your only finding UK channels all the time it seems to me that your dish is stuck on 28.2? east.
Listen mate your best bet is to call the installer back and get him to sort it after hearing something being said like this it appears another 10 gallon hat has rode out of dodge.
we are not worthy
thanks for your help
