Can't view Vu+ duo in network.
  • septicsmurf
    • Feb 2012
    • 401
    Hi all. Just flashed Vix 2.4 on my vu+ duo and love the image.
    Problem is when I go into my network on my pc I can't see my vu+ duo hdd.
    I tried my blackhole backup again and it was fine. Put vix 2.4 back on and i couldn't see it in the network again.
    I can connect via ftp and telnet though.
    Any ideas?
  • cactikid
    • 12017
    network and box may need a reboot,as in off for a min then on
    • septicsmurf
      • Feb 2012
      • 401
      I just gave that a go, no luck.
      I even unplugged the router for a minute and then restarted everything.
      Any other ideas anyone?
      • dell_xps
        • 2558
        Enable samba in the network settings m8, if using an apple enable afs also.
        HTH
        • septicsmurf
          • Feb 2012
          • 401
          Thanks mate, job done.
          Nice one.
          • killbillbst
            • Oct 2011
            Helped my out also, cheers!
            • joetwizzy
              • May 2011
              • 322
              I have enable afp but the share is connected as guest and is read only. What is the user/pass to enable write?
              • dell_xps
                • 2558
                root/root
                HTH
                • joetwizzy
                  • May 2011
                  • 322
                  Originally posted by dell_xps
                  root/root
                  HTH
                  it's not having it :S
                  • dell_xps
                    • 2558
                    Just root in password, leave username blank.
                    • joetwizzy
                      • May 2011
                      • 322
                      hmmm, it logs in fine with ftp and telnet using root/password .
                      • dell_xps
                        • 2558
                        username --- leave it blank m8
                        password--- root
                        • dell_xps
                          • 2558
                          Oh have you enabled samba in network settings also ?, you need that :-)
                          • joetwizzy
                            • May 2011
                            • 322
                            i have enabled afp. I use a mac. It needs a username. :S
                            • RuberDuck
                              • 1724
                              password--- root
                              should that not be the other way round ?.
                              username--- root
                              password --- leave it blank m8
