Vu+ Duo is it really suitable for me
I can wait a little while. I have my orig cheap'as'chips Ross box to view and drive the motor/dish.
I still have to get this temporary doorstop shipped back from whence it came, then get my cash back via Paypal, so in no desperate hurry.
So its a valid question - when are the new units out, as I'm happy to wait a while if the prices of the current stock (Duo or Ultimo) is likely to go down
if your in no rush then take a look at the vu+uno and when the twin tuner is released you will have a faster twin tuner box with better tuners for around the same price as the duo... as for the duo2 i cant see you getting much change from ?500 if you buy it on release, regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
the uno has blind scan? does that mean it will update the ch list when a ch moves? when do you think the x2 sat tuner will be out and price?if your in no rush then take a look at the vu+uno and when the twin tuner is released you will have a faster twin tuner box with better tuners for around the same price as the duo... as for the duo2 i cant see you getting much change from ?500 if you buy it on release, regards mdt
oh yeahhhhComment
Hmmm, not considered this.if your in no rush then take a look at the vu+uno and when the twin tuner is released you will have a faster twin tuner box with better tuners for around the same price as the duo... as for the duo2 i cant see you getting much change from ?500 if you buy it on release, regards mdt
So this Uno has room for a second HD tuner (cable, sat or terr) bit like the dreamboxes, and these tuners are being released soon? if so what est cost for the second tuner?Comment
no blindscan does not auto update your channel lists, it does however allow you to scan a full satellite pulling in every thing thats broadcasting.Comment
not quite.
The uno has a single plug and play tuner slot in which you can fit a DVB-S2 or a combo DVB-T/C card. Vu however will soon release a DUAL DVB-S2 card allowing you to turn it into a twin tuner box.Comment
Just been looking at spec of Uno.
Looking at the pics it seems to have single sat tuner with loop out as standard.
There's not a second gap in the backplate for another tuner, so what gives?
Are you likely to get a new backplate with the second tuner, or do you get a hacksaw to the backplate
Or is it just that you replace the standard tuner card for a new one with two tuners and lose the loop-out
Edit - Just seem RD's answer - sweetComment
and the obvious next two questions - when and how much (est)??Comment
Post 121
Imagine 3 of those in an Ultimo !!!At the end of this month, ill get my first shipment from Vu+ with these Dual Tuners.
Price will be around 45-50 EUR.
Making your Uno the new Duo ;-)
Get one here:
Vu-Uno-Ultimo-Plug-and-Play-DVB-S2-Tuner-Module.htmlLast edited by meggiedude; 22 June, 2012, 16:30.Comment
Ah, OK - my bad
I made the mistake of trusting google. ooops
Bit naughty with the description then:
True for the Ultimo - not for the UnoThis is a plug and play additional tuner for the
Vu+ Uno
Vu+ UltimoLast edited by meggiedude; 22 June, 2012, 17:11.Comment
If I went down the route of getting genuine Uno or Duo, I am interested in adding usb DVB-T2 terrestrial HD tuner stick (ideally dual tuner) to the box.
So for instance if I purchased Uno I'd eventually have twin Sat tuners (when pluggable twin DVB-S2 card avail) + two DVB-T2 tuners via the usb stick.
Is this possible, and if so, what DVB-T2 tuner sticks are compatible with VIX or BH?Comment
