Star Plus HD not working on Vu duo
  • bigup
    • 69
    guys, got a slight issue, star plus hd working fine yesterday, then today it stopped working on my vu duo (genuine)
    tried different channel lists (latest vhannibal etc) and all the same, checked lyngsat and using the same frequency but i cant get any of the channels on 10936 V (itv, stv)
    ive reflashed my vu duo to latest BH image, all other channels work but what is odd is i have a DM800 in another room and star plus hd works fine on that
    i have a motor dish (tuner A) and static dish (tuner B) on my vu duo, tried scanning 10936 V on both and doesn't pick it up
    so bit confused, any ideas?
  • akicox
    • Nov 2010
    hi i have the same problem star plus hd works on my tecnomate hd but not on my vu duo tryed everytink but no joy
    • bigup
      • 69
      When did it happen to yours mate ?
      • kasimfida
        • Mar 2012
        • 5
        hi mate,
        same problem..it went down yesterday on my vu duo
        iv tried searching the fequency but no success
        kas
        • irfy
          • 27
          Star Plus HD
          Originally posted by kasimfida
          hi mate,
          kas
          Hi I have the same issue here on Solo2 and Duo.. Star Plus HD comes up with "Tune Failed" both boxes on latest VIX build 668. All other chans are fine. If its a freq change pls can someone kindly let us know. Thanx
          • bigup
            • 69
            Glad it ain't just me, ought my tuner was on its way out.
            Don't think it's a freq change as it works on my dm800.
            Im sure someone wil know what to do
            • shaks08
              • 37
              I have same problem but its on my dm800 its showing 'tune failed' since yesterday...i've asked others and there's all working fine...kind of weird
              • allyzaman
                • Sep 2011
                Solution
                Hi
                I had the same problem on my DM800 I just did the auto scan and Star HD started working.
                Just run a fresh scan
                • bigup
                  • 69
                  Originally posted by allyzaman
                  Hi
                  Can you post the frequency the channel is now on please ?
                  • DOUGALMCD
                    • May 2011
                    • 3229
                    HD 10936 vertical 23000 8/9
                    SD 11261 horizontal 27500 2/3
                    • kasimfida
                      • Mar 2012
                      • 5
                      hi pal,
                      i have just searched the hd frequency, and the it says 0 channels found... it was working fine til 2 days ago... all the other channels working fine but star plus hd
                      any help?
                      kas
                      • DOUGALMCD
                        • May 2011
                        • 3229
                        Got mate to check on vu and they are ok.
                        • kasimfida
                          • Mar 2012
                          • 5
                          hi pal,
                          i just did a fresh scan, and its working again
                          kind regards.
                          kas
                          • shaks08
                            • 37
                            I got mine on by doing a network scan, first you need to delete the non working channel and than do a manual scan with having network scan to 'yes'...
                            you can also try this frequency first:
                            freq; 10935
                            sym rate; 23000
                            vertical
                            fec; 2/3
                            8PSK
                            rolloff; 0.25
                            • GAH
                              • 57
                              Hi,
                              FEC is now 7/8, changed from 8/9. Also affected STV HD and one of the ITV HD variants
                              GAH
