DUO2 and blackhole help
This topic is closed.
  • manutd4life
    • 132
    Right i ahve managed to get blackhole 2.0.5 on the duo 2. I have 2 problems.
    1. I cant find the tspanel in the downloads or plugins.
    2. I set my satelite onto 28.2 with my other reciever, but when i change the recievers over to the duo2 and try to watch a FTA channel on 28.2, the reciever moves the satelite dish slightly so i have no signal. I move it back to the correct position via the settings but it moves again when i go to a FTA channel again.
    i have put in my long and latitude.
    Not sure what i can do, i have a diseqc motor on the dish and has been set up around 12 months
  • digicon
    • 8261
    TSPanel you will have to install yourself as most of the Online download servers don't hold it any more but it is available from this forum if you do a search, As for the Motor positioner you may be better entering your Lon & Lat back in via the Duo2 and send the Motor to '0' so it resets the motor table in the Motor itself and then try again
    • manutd4life
      • 132
      thanks mate, do i install the tspanel via my usb and install it like i flash the image or do i need to do it via /tmp?
      is that all i need or do i need to download tsmedia too?
      trying vucc now, do I need tsmedia?
      • manutd4life
        • 132
        ive installed cccam 2.2.1 and 2.3.0, wasnt sure which one i needed. i cant find where i need to add the info.
        • septicsmurf
          • Feb 2012
          • 401
          Can't really say to much about it, but you need to edit your .cfg file and ftp it to /etc.
          • manutd4life
            • 132
            So ill just copy it from my technomate and paste it in there like a dreambox.
            • manutd4life
              • 132
              done that but nothing happening
              • manutd4life
                • 132
                My reciever is currently a FTA one at the minute.
                I have installed blackhole, tspanel and the cfg file. I have pressed enable and the light is green.
                Am i missing anything or should it be up and running?
                • septicsmurf
                  • Feb 2012
                  • 401
                  Whch version cccam did you install?
                  • manutd4life
                    • 132
                    2.2.1 ccam AND 2.3.0, tried both and got 2.2.1 enabled constantly now
                    • manutd4life
                      • 132
                      all sorted now.
                      Thanks digicon, benny/9, septicsmurf and aftermath
