Stick any Duo image on a clone m8, as long as its a V2 box, if not update the kernal on it, and then use any image.
HTH
PS there are no clone images !!
just to get it in my thick head, do I flash my default firmware vu+ duo with kernel inside vix2.4.158 download then go on to flash image? must I reboot after kernel flash then flash image
many thanks
I would do a bit more reading mate before you want to start flashing. If you have vix 2.4.158 then you have the latest bootloader and I assume you have an original duo. Remember if you do a new flash it will wipe out settings already on box.You should do a backup before you flash box.If you need to ask anything start a new thread.hth
