Sky ROI Sports channels 1to 4 work but Sky ROI Sports 5 does not work just black screen
Sorry not to reply earlier but been away for a couple days couldnt check my box, just checked my ss5 ROI and it's working. There's 2 ss5 ROI, one works one doesn't you need to manual rescan 12207 V 27500 you should get 2x ss5 ROI the one with PID 1312 works.Comment
IIRC eir sports 2 HD isn't available in NI, it's only available in ROI channel 460, so if you can get that channel there's a good chance you're in receipt of an ROI card.
Edit: just had a quick look at the EPG for SS5 ROI tomorrow 13th Aug and it does say the 3 o'clock footie is on, this channel at present does clear for meAttached FilesLast edited by martin035; 12 August, 2016, 19:50.Comment
is there any guides to do this for guys new to this?
thanksComment
Everton v Tottenham
August 20
Burnley v Liverpool
August 27
Watford v Arsenal
September 10
Stoke v Tottenham
September 17
Hull v Arsenal
September 24
Swansea v Manchester Cityinformation given is to be used for educational purposes only
Don't Forget To Say Thanks If You Like My Post
IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
If It Ain't Broke Don't Fix ItComment
One of 2 ways either install Cwaites channel list, he has an Irish Fav which has SS5 ROI in it;
The latest CWAITE (previously sattv5) Sky Numbered Channel Lists can be found here. (http://cwaite.dyndns.tv) We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote
Or do a TP_list search, follow the instructions in this thread;
If some of your channels say scrambled after a frequency change's the easiest way to fix them..... If you don't know how to update the box with Aj's or Sattv5 channel list (which are the best i have found so far ) via usb then follow the info below..... You need to find out which transponder the channel has moved to..... PlzComment
