Page 2 of 20 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 290
  1. #16
    Member darvash's Avatar
    Aug 2009
    Copenhagen Denmark
    Quote Originally Posted by bodyguard View Post
    Is this the best firmware?
    Yes It is the best so far as many bugs have been removed incl. problems with audio sync and smooth playing for long MKV files
    *****Don?t argue with idiots. They drag you down to their level and beat you with experience*****
  2. #17
    Jul 2011
    i have uncheck and check again ,nothing happen.i did factory reset before i load firmware,channel list and ccam.cfg
  3. #18
    Jul 2011
    It ok now,i went to satellite list uncheck it and exit ,exit ,exit,and went back again as you said in satellite list check it back ,all sorted,and everytime i was exiting after unchecking and checking it was saving .Thanks for your help
  4. #19
    Aug 2009
    Copenhagen Denmark
    Quote Originally Posted by rkabishi View Post
    You are welcome. Glad you got it sorted out!
  5. #20
    Jun 2011
    California,USA
    Default USA
    does anyone have a us version.
  6. #21
    Jul 2011
    i hope that it will solve my every 3/4 seconds blackscreens on the rtl 4,5,6,7 sbs6 hd channels
    it is better then before then i only had sound but afcourse it should be smooth
    i have a azbox and that one never failed me
    but this openbox s9 gives me a lot of frustration
  7. #22
    Aug 2009
    Copenhagen Denmark
    Quote Originally Posted by juanflx View Post
    You can download it OpenBOXS9 America_
    This software is both for S9 S10
  8. #23
    Jul 2011
    Cant get my cona>< cam + card working
  9. #24
    Oct 2010
    Quote Originally Posted by darvash View Post
    New software Europe version and America version dated 10/07/2011 for Skybox/openbox S9 an S10
    Software is both for S9 and S10
    Its main features are as follows:
    1. Solving rebotting problem when we watch channels by CCCAM account
    2.Solving the channel freezing problem when the volum set up or dowm
    3. Solving subtitle changing problem
    (Notes: please come into "language" menue, and setup the favourite language under "teletext",
    then the subtitle will default the corresponding language
    4. the customer can change the logo m2v by themself
    5.updated mediaplayer to support some video formats--VCD(MPEG1),DVD(MPEG2),AVC,MP4(H.264)
    6.modified background internet connect to server
    7.add to 32 FAV list
    8. Add HDMI and AV output at the same time
    Instructions. Please read this carefully before upgrade
    This firmware is not safe for clone boxes. If you don?t know that your box is original or clone please check her
    If you want to keep all your different settings and current firmware then you need to dump on a USB flash disk
    The first thing to do is save the downloaded firmware file on the root of a USB flash disk,
    Plug USB disk to the back of your receiver. It will be recognized by the receiver.
    1. Before upgrade, do a Factory Reset:
    * Go to TOOLS menu and click on Factory Settings
    * Click Yes to continue. The receiver will go to factory default and restart.
    2. Upgrade Firmware:
    * Click on MENU and go to TOOLS menu again
    * Scroll down to "Upgrade by USB"
    * Click on START
    * Choose Image File[*.abs]
    * After the loading is completed, Accept the upgrade.
    * The receiver will restart.
    3. After upgrade, do another Factory Reset:
    This software will be replaced and updated as soon there is a new version.
    Pease use the red thanks button at the right bottom corner if this post is helpful for you
    Hi all
    I have upgraded this europeen software on my openbox S9 clone but nothing was happened even thought you wrote '' This firmware is not safe for clone boxes '' everything is working ok.
  10. #25
    Jun 2011
    I have installed this firmware, and I am pleaseed at the updated version. Living in Spain Iam using Astra 1Eurobird, 28.2, Astra 3A 23.5 Astra 1H/ 19.2 and shortly to add Hotbird. I am using 1 x 90cm dish with upto 4 x LNB's a and 1 x 2.4m dish.
    The new firm ware does allow the viewing of sky news via transponder 12.207 27500 V, channel name 8039, this does not break up or freeze the S9 as past software did, when changing the channel on sky news hung the box.
    I have noticed that the films from a certain company that are transmitted in SD format drop out during the day, but by switching to one of the above sat. I can view the lost channels, or view some on 28.2 in HD or the total film package via 19.2, although a german feed, these will be broad cast in english if origional was made in english. Thanks for the firmware keep them coming.
  11. #26
    Aug 2009
    Copenhagen Denmark
    Default New software/image for S10 dated 13/07/11
    Hi Gays
    Added new image/software for openbox/skybox S10 dated 21/06/11
    Please check the first post
  12. #27
    Nov 2010
    Hi Gays
    Added new image/software for openbox/skybox S10 dated 13/07/11
    Hey
    Filse inside the zip reads as "OPENBOX_S10_110621" Doesn't that mean its 21st of June 2011??
  13. #28
    Aug 2009
    Copenhagen Denmark
    Quote Originally Posted by waqypaqy View Post
    Hey
    Thanks bud I did uploaded the wrong file (now changed)
  14. #29
    Jun 2011
    thanks, nice firmware, i live in mexico and work it fine with european version and american satellites
  15. #30
    Jun 2010
    hi guys
    what is the difference between the versions
    I thought they are all the same
