Results 1 to 8 of 8
    Feb 2011
    Almeria, Spain
    Default how to read and writing micros motorolla freescale hc08 hc11 hc12 hs912??
    Hello friends
    to see if they can help...
    Is to read and write micros family freescale hc08 6811 68hc12 hs912 motorolla....
    To see I mean I've had Chinese upa programmer without success, I've had developer xprog-m without success
    've had original upa House without success and I've had to return because I do not read.
    Pinear a motorolla with 6-7 pin micro already is difficult but if above the micro has 100-112 pins even much more difficult if not impossible.
    and of course all this pineando according to the datasheet of the micro and each programmer according to the indications.
    Then wonder:
    What are the pins needed to be able to do a reading and writing of the micro-motorolla without having to pinear 7-8 pin.
    Because the voltage Vdd pin are needed and then the pins of data transmission trx and reception of data
    rx, but which are necessary for pinear well the micro and let me correct reading....
    Because another option would be for example in airbag switchboards, read and write the microphone through the rules on the control box as it does the machine super vag k can
    but can you tell how to reduce to the minimum the number of connectors of the micro way motorolla.
    If food through the connection of the switchboard of airbag connector (connecting only positives and negatives) and pinear in the micro only motorolla necessary pin for data transmission and that allows reading and writing of the micro...
    Can help me, as do a reading and writing easier through rules just connect 2-3 pin.
    Can help. because I have a big problem with the micros motorolla frrescale
    sounds or that programmers for microcontrollers motorola freescale non-upa-usb, and that works.
    As to launch the programmer xprog-m and make it work because with the motorolla monkeys when was pinea appears "device is silence"
    greetings I hope your answer
    thank you and happy year 2012
    KILL_THE_IMMO's Avatar
    spain
    buy an omega programmer and ^roblem will be solved
    --------HELP OTHER TO BE HELPED--------------
    Feb 2011
    Almeria, Spain
    Quote Originally Posted by KILL_THE_IMMO View Post
    hello kill the immo.
    you've had problems for the motorolla micros?
    Pins are required to read and program motorolla hc908 6811 68hc12 micro hs912
    how the omega programmer there PIN must connect
    in that work, that buses have worked
    i hope this respuest
    Dec 2009
    Prussia
    Quote Originally Posted by javiercj View Post
    Hello friends
    Then wonder:
    Use ETL programmer.....easy
    Feb 2011
    Almeria, Spain
    Quote Originally Posted by TULGEYWOODMAN View Post
    hello tulgeywoodman
    thanks for the info and reporting
    you can tell as is pinean these micros motorolla accessing the eeprom of the micro
    where and how can I buy the programmer etl
    micros supports
    hope your answer
    thank you
    DK Veteran elchip's Avatar
    Nov 2009
    EU
    Exclamation
    hello tulgeywoodman
    micros supports
    hope your answer
    thank you
    First at all 99% of these programmer's you was count do Motorola MCU OK.It's no problem to it's from China so maybe is better to you select another job not auto electronic or electronic in base.Maybe is better to you start be some touristic manager in beautiful Spain...
    Best regard's
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
    bram380's Avatar
    Aug 2009
    Indonesia +628153111774
    Quote Originally Posted by elchip View Post
    Best regard's
    Hi elchip...Happy New Years 2012
    Feb 2011
    Almeria, Spain
    Best regard's
    Thanks for responding.
    It take this into account
    always comes in handy, a fellow like you to ask
    greetings
