Page 7 of 140 FirstFirst ... 234567891011121757107 ... LastLast
Results 91 to 105 of 2097
Thread: kess v2 clone
  1. #91
    Jan 2010
    Just tested on:
    X5 3.0d 2003 R/W Ok
    Master 2.5dci 2004 R/W ok
    Passat 1.9tdi 2003 R/W ok
    ....k-line working no problem.
  2. The Following 10 Users Say Thank You to cheester For This Useful Post:
    Artilect (27th March, 2013), bondiblu (27th March, 2013), dav29200 (20th April, 2013), didi_du_93000 (27th March, 2013), mauronow (9th April, 2013), mexanico1971 (29th March, 2013), Nio (2nd April, 2013), niwat_spp (28th March, 2013), pasquale78 (27th March, 2013), vasco fernandes (2nd April, 2013)
  3. #92
    Jan 2010
    2004 Vw Turan 1.9tdi edc16 r/w ok
  4. The Following 6 Users Say Thank You to cheester For This Useful Post:
    Artilect (29th March, 2013), dav29200 (20th April, 2013), mauronow (9th April, 2013), Nio (2nd April, 2013), niwat_spp (29th March, 2013), wiski (21st April, 2013)
  5. #93
    Senior Member mauronow's Avatar
    Sep 2012
    bosch 7.4.4 peugeot
    r/w perfect obd.
  6. The Following 6 Users Say Thank You to mauronow For This Useful Post:
    Artilect (29th March, 2013), dav29200 (20th April, 2013), mexanico1971 (29th March, 2013), Nio (2nd April, 2013), niwat_spp (29th March, 2013), wiski (21st April, 2013)
  7. #94
    Jan 2010
    don't forget turn off internet. software not test by me. v1.94
    KSuite.rar
  8. The Following 5 Users Say Thank You to niwat_spp For This Useful Post:
    apv (17th June, 2013), autoparty1978 (13th February, 2014), euroscan1 (28th August, 2013), mauronow (31st March, 2013), mexanico1971 (31st March, 2013)
  9. #95
    Aug 2012
    This is software update from a genuine tool?
  10. #96
    Aug 2012
    I can't get past Trojan :-(
  11. #97
    Aug 2012
    KESS V2 Clone without Epoxy/Pitch ..........P1020501.JPG
  12. The Following 2 Users Say Thank You to Plowman For This Useful Post:
    bondiblu (31st March, 2013), dav29200 (20th April, 2013)
  13. #98
    moky's Avatar
    Apr 2010
    Behind you
    Don't update clone ,if update dead...
  14. The Following User Says Thank You to moky For This Useful Post:
    Plowman (31st March, 2013)
  15. #99
    Aug 2012
    Yes, thanks. I thought this version might have been something special
  16. The Following User Says Thank You to Plowman For This Useful Post:
  17. #100
    Sep 2012
    for used the micro sd?
    thanks!
  18. #101
    moky's Avatar
    Apr 2010
    Behind you
    Someone tested kess in boot mode tricore edc17 ? Thx
  19. #102
    Jun 2009
    Is someone know can I disable or enable DTC with this clone kess?
    Is the clone kess came with the custom tuners program?
    Is the clone kess support Isuzu dmax via obd-II
    Is the clone kess support GM 6.6 LML via obd-II
    Is the kess clone came with info and wiring diagram for BDM ?
    shay
    shay
  20. The Following User Says Thank You to shay31 For This Useful Post:
  21. #103
    Aug 2012
    @ Moky Yes, EDC17 Tricore works fine ;-)
  22. The Following 3 Users Say Thank You to Plowman For This Useful Post:
    dav29200 (20th April, 2013), mauronow (2nd April, 2013), wiski (21st April, 2013)
  23. #104
    Aug 2012
    Quote Originally Posted by shay31 View Post
    shay
    shay
    Answer is no to all questions
  24. #105
    moky's Avatar
    Apr 2010
    Behind you
    Just ordered one i will send you infos after tests
  25. The Following 2 Users Say Thank You to moky For This Useful Post:
    glk96000 (2nd April, 2013), jr2185 (3rd April, 2013)
