Results 1 to 12 of 12
Thread: Dead Skybox F5
    Apr 2013
    Default Dead Skybox F5
    After finally getting the box up and running, I went to do a blind satellite scan and apparently the box doesn't like this.
    It now wont turn on at all.
    I've seen tutorials on how to fix this, but I'm not sure weather to contact the seller or just try this?
    Any help?
    Mar 2011
    try this m8
    my skybox f3 was completely bricked, wouldnt turn on, no power at all. Ive just fixed it using this software which i picked up from another forum. Its similar to another software in this forum that is specific to openbox s9-11. This one definitly works on the f3.
    You need a null modem connection. Mine worked on a USB to 9 pin adaptor but some dont, best to use a PC with a dedicated 9 Pin socket
    Just unzip the file, Open the folder, then open EromUpgrade.exe.
    Make sure box is switched off, then select your port, select your firmware image and tick the checkbox for include bootloader.
    Press next, then switch on your box and follow the on screen procedures
    DK Veteran mahrkpat's Avatar
    Jun 2012
    Quote Originally Posted by alchristou View Post
    Any help?
    If under warranty return to seller shouldn't brick just because you did a blind scan.
    DK Veteran darcu5's Avatar
    Jun 2011
    Bolton, Lancs.
    my spare f5 bricked doing a scan, no lights at all on it but after leaving it pluged in it got warm so i reflashed it and it's worked fine since
    If it isn't broke, don't try fixin it..!!!
    Apr 2013
    Quote Originally Posted by darcu5 View Post
    How do you reflash it?
    Apr 2013
    Quote Originally Posted by mahrkpat View Post
    Would they be OK refunding it if I had a c............................ in do you think?
    Last edited by digicon; 30th January, 2014 at 08:23 PM. Reason: Read the Rules Please Regrading C/S
    Jun 2012
    Would they be OK refunding it if I had a cline in do you think?
    Better not with a cline in it.
    You will need a null modem cable then follow this recovery guide.
    Also if you don't have serial port on your pc you will have to get a USB Serial converter, I would recommend HL-340 it supports WinXP, Vista and Win7 32 bit.
    Download this recovery tool:Recovery Kit SKYBOX F5.rar
  8. The Following User Says Thank You to mahrkpat For This Useful Post:
    Acdebarbier (18th May, 2013)
  9. #8
    Apr 2013
    Thanks. Is it important to have the full handshaking feature, does this usb serial converter have this function?
    Would this be alright?
    USB Converter to Serial Cable ,USB Convert COM Port USB-RS232 HL-340 | eBay
  10. #9
    Jun 2012
    Should be fine and when using the recovery software remember to tick the include boot loader option.
  11. #10
    Nov 2012
    Hi, My mates skybox f5 is stuck on the boot load. count's up to 100 the stops and displays l100 on the face. has anyone has this problem. I don't think i can do the recovery with the null cable as the f5 doesn't have a power button on the box and as soon as you plug the power lead it tries to boot. Any help would be gratefully received.
  12. #11
    Sep 2013
    Just one question. Which side of cable goes to skybox USB or RS232 ? Or it doesen't matter ?
  13. #12
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by mleczus1 View Post
    If you are using a USB to RS232 converter, then it plugs into the USB port of your pc/laptop to convert it to a RS232 port. You then use a null modem cable to connect from the adapter to the RS232 port on the skybox.
