Results 1 to 14 of 14
Hybrid View
    Dec 2008
    stockport
    no, mate, nothing has changed in uk. ignore eirejk.what box have you got and have you got correct f/ware for it?
    try menu, 1570, default then back to slyspts. wait for update. also, missing channels can sometimes be found after 999. loads of others there. try scan with t/pest as well. i get stuff with t/pest and xc/w..in stockport.
    do you do factory reset as well? hope this helps. ynwa
    maca's Avatar
    Feb 2009
    liverpool
    Quote Originally Posted by boomer39 View Post
    well said m8.. maca..
    Dec 2008
    i have got 'the box' (thats what it says on the front anyway). this is what info it gives me API ver: 4.51e_E Bootver: 7.0 9.July 2007. i have tried all this but am still getting the normals ones i get with exc&w. will i have to install any new software or anything or will the problem sort it self out in time if i just keep on rescanning it? if i have to install any new software how? i am in oldham using virgin media if it helps. thanks mate
    Dec 2008
    stockport
    Quote Originally Posted by oli949 View Post
    yes, mate, you need latest software. pretty sure you have an sv1 or sv2. different software for all 4 boxes. you need a null modem cable to download from pc to your box. also you need to get software from the above red stickies. it can be a bit daunting at first,but well worth the effort. i'm not used to sv1/2 but the guys here will help....
    Dec 2008
    hi mate. thanks for your help. one last question though. when should my box (sv2) be turned off and when during the update should it be turned on?
    Dec 2008
    thank you all for your help. i've fixed my box: hooray!
