Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Apr 2010
    Heaven or Hell
    Default W221 CGW flash kill with original abritus
    2011 CDI W221 CGW flash both and eeprom work dump need.
    my abrtius original kill CGW w221. I need flash both and eeprom dump work.
    regards
    Fec001's Avatar
    Apr 2010
    abritus warn you to make backup about CGW flash and eprom before you start procedure. Have you done this? I'm sure abritus support will help you.
    Apr 2010
    Heaven or Hell
    it not warning back up message.
    Fec001's Avatar
    Apr 2010
    it's in PDF manual
    Apr 2010
    Heaven or Hell
    I dont see any info. after make read it. now need it dumps
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    Diesel? Petrol?
    Read more carefully next time. Read eeprom, read flash of CGW.
    Go to odometer calibration. Check boxes "have eeprom" and "have flash". Odometer re-calibration will take about 5-10 seconds.
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
    Apr 2010
    Heaven or Hell
    Quote Originally Posted by lupu_sandu View Post
    Diesel? Petrol?
    dont read eeprom via obd abritus now. I tried cgw explorer abritus for read but not accept.
    I think only manual read and write firstly after recalc via abritus.
    car is diesel
    dave11674's Avatar
    Florida, UK
    GOLDEN RULE
    always read and save files before doing modification mate
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    In pdf for 221, you can read this:
    First of all you need to read the EEPROM and the Flash memories of the Central Gateway control unit
    by using the Special Function “CGW (ZGW) Explorer). You need to store the EEPROM and Flash
    dumps as files on your hard drive.
    Please, note that the Abrites Commander for Mercedes will also automatically make a backup of the
    EEPROM and Flash memories when it reads them. These backup files can be found in the same folder
    where the software is installed (which is normally “C:\Program Files\ABRITES software for ID
    XXXXXX\Mercedes”)
    and this:
    ATTENTION: You can speed-up the odometer correction process if you load the FLASH and
    EEPROM dumps, if you have already read them with the “CGW Explorer” special function. In fact it is
    recommended to always use the loaded the dumps that you have already saved.
    Apr 2010
    Heaven or Hell
    now need manual read flash 1 and flash 2 work file. Abritus read it both and mixed file save. need it extract flashs files
  11. #11
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    W221 have only one flash 512kb and 16kb eeprom in CGW.
  12. The Following User Says Thank You to lupu_sandu For This Useful Post:
    yugo45 (29th September, 2015)
  13. #12
    Apr 2010
    Heaven or Hell
    it have two pieces 29AL004xxxx and 95128
  14. The Following User Says Thank You to Safety For This Useful Post:
    vanos batam (18th June, 2021)
  15. #13
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    Read and post here both flash and eeprom.
  16. #14
    Apr 2010
    Heaven or Hell
    here all dumps .
  17. #15
    Apr 2010
    Heaven or Hell
    solved .
