Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 41
  1. #16
    Mario3's Avatar
    Dec 2014
    Sorry to hijack tread but i had similar issues a few days ago and dont have to much experience with this type of immo system. Elv stuck in open position and bloked the engine start, i managed to make immo off so the guy can drive his car. And i did read that a new elv has to be buyed, why can not a used one be made virgin ? Thats my question? And i didnt open it to se what type of memory it has, but i did found in avdi dump tool that there is 908 motorola ? So can it be done or not ?
  2. #17
    Oct 2010
    Becouse used is also often bad as yours and new esl is quite cheap
  3. #18
    Senior Member sazimam11's Avatar
    Jan 2012
    Praha, Czech republic
    Quote Originally Posted by yugo45 View Post
    With New ESL you do not need to enter Pin, go starring to adaptation Ch 51.
    New ESL comes Virgin and it is unlocked , that why no need pin.
    Well, that sound OK for me but the ESL locked itself after a minute and now it blocks the power supply wit key in ignition - terminal 15 and I cannot comunicate with the immo unit . Is there any goaround ?
    Internally THERE is motorola MC68HC908AZ32 mask 4L52H in 64pin QFP FYI
  4. #19
    Mario3's Avatar
    Dec 2014
    Quote Originally Posted by twincam View Post
    I know but why can i not use a elv from scrapyard make it virgin and code it to car. Its around 160e where i live incl. coding
  5. #20
    Apr 2011
    in lebanon
    Hello.
    1) the manual above which i write to use pin in Security Access-16, before Adaption -10 in Channel 051. i always do this procedure in each time when come to my garage this job.
    2) & in this link it show the same with positive result by using the pin before going to adapt 51.http://forums.ross-tech.com/showthread.php?784#post5511
  6. #21
    Apr 2011
    in lebanon
    Quote Originally Posted by Mario3 View Post
    Hello.
    in avdi this function can show you security access code = pin + The function displays also the component protection bytes. just.
  7. #22
    Apr 2011
    in lebanon
    Quote Originally Posted by sazimam11 View Post
    Hello.
    1) write original dump in comfort module & after you need to wake the CAN Bus, try matching with the 4-way flashers turned on and the high beam held back in the flash-to-pass position to have communication with immo by obd2.and when u get the communication try re adapt the new (ELV)
    2) many years ago done with me used ELV by disolder (68hc908) from original to new used, but never i try in (brand new).
  8. #23
    Mario3's Avatar
    Dec 2014
    Did you read my post ? The question is not how to read data out of it but to virginise a used elv so it can be adapted as a new unit
  9. #24
    yugo45's Avatar
    Apr 2010
    Quote Originally Posted by haroutioun View Post
    Hello.
    Not necessary put pin ,
    same thing in Mk4 cluster , Ross-Tech and everyone was telling for MK4 NEW cluster need to enter Pin, but it does not need.
    You can test this with Mk4 cluster , make it Virgin and go straight to ch 50 , you will see it does not need pin.
    Audi Rb4 Immo 3 , Audi A6 C5 immo 3 same thing.
  10. #25
    Top Poster + TECH's Avatar
    Jan 2010
    I have look for the same way at past , I didn't found a way to virgin the used. Only if you have virgin files read from virgin one!
  11. #26
    yugo45's Avatar
    Apr 2010
    It may unlock when time goes out.
    By pressing Brake pedal for 30 sec and have hazards on all time , you can wake up Can Bus and you can access 25-immobilizer .
  12. The Following User Says Thank You to yugo45 For This Useful Post:
    sazimam11 (25th October, 2015)
  13. #27
    Jan 2010
    If step motor work once without adapted then its locked, try to open it and remove at open stage.
  14. #28
    Apr 2011
    in lebanon
    Hello,
    yes friend that's right, i just try give on this function in avdi dump tool,function for pin + cs show.
  15. #29
    Apr 2011
    in lebanon
    Hello.
    OK your answer right.but i never see Ross-Tech telling about golf 4 new cluster need pin code in ascces-16, he show us direct to Chanel 50, but the procedure by use pin in (access 16) is not wrong for passat comfort,so all here in DK we know this channels how use it,any way i accept your idea.
  16. #30
    Jan 2012
    YEs man, this worked for me. It seems like I made a bad sequence ans the ESL locked itself.
    After batt conection and wake up the GW the car seems to have no power but it has at least IMMO unit. It is acessible via VAG and this procedure worked fine > http://forums.ross-tech.com/showthread.php?784#post5511
    Did not need to open/disassemble the ESL unit, fortunatelly. The cost of this is 90EUR now, so it is not worth of any risk with its repairs.
