Page 10 of 146 FirstFirst ... 567891011121314152060110 ... LastLast
Results 136 to 150 of 2176
  1. #136
    EARTH
    Erase please DTC P1570 00.
    I need to clear DTC after immooff car works okay, but not erase error code. Used ecu. second hand . P15700 00 not erase in ecu.
    OFF ok avdi AMAROK EDC17C54 0281017903.zip
  2. #137
    Nov 2015
    Romania
    Can you please delete p1923 and p0036 . Also lambda off if it is posible
  3. #138
    Jun 2015
    Poland
    Can u delete P0545 in edc16c31 ?
    bmwe60edc16c31kendal.zip
    Thank's a lot!
  4. #139
    Jan 2010
    p0545 dtc off test
  5. #140
    imcumen's Avatar
    Feb 2009
    FRANCE
    Hello
    Meagane 2 RS JC S3000
    Please i need remove DTC P0130, P0135, P0141
    THX
    Regards
  6. #141
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Quote Originally Posted by imcumen View Post
    Hello
    THX
    Regards
    Sorry this ECU not supported at my topic.
    But for that's error needed make car repair not DTC off.
    I can remove second lamda from you (ex cat out). But first one are needed to regulate engine work.
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
  7. The Following User Says Thank You to CustomCars For This Useful Post:
    pike (24th December, 2015)
  8. #142
    imcumen's Avatar
    Feb 2009
    FRANCE
    Quote Originally Posted by CustomCars View Post
    Hi Customcar
    thank you for your help
    I only have this DTC P0135 has deleted
    Regards
  9. #143
    DK Veteran DjRomeoR's Avatar
    Nov 2011
    Garage...
    Hello, in my renault traffic 2003 year edc15c2 need remove this fault code maybe some one can delete this dtc P0400 in ecu ?i can't upluad to dk manage, so upluad in other space:http://www.filedropper.com/renaulted...002003trafic22
  10. #144
    May 2010
    Europe
    Hello,
    Need help with remove fault P0403 (egr valve)
    Passat 1.6 tdi, Comp PCR 2.1
    Car not running in the limp mode, only fault and check lamp on every 10 days...
    Regards
  11. #145
    waldi1979's Avatar
    Dec 2010
    Here you are.
  12. The Following 4 Users Say Thank You to waldi1979 For This Useful Post:
    borysgo2 (22nd February, 2016), dpcmsx (28th February, 2016), GianniNOS (18th January, 2016), Nocni (26th December, 2015)
  13. #146
    May 2010
    Europe
    waldi1979, it's perfect!
    thank you so much for the help I'll remember
  14. #147
    Mar 2010
    Poland
    Default dtc
    p0400 disabled
  15. #148
    Jun 2010
    Spain
    Does not work still has an error
    Hello
    Ned DTC off P0401.
    HW: 0281011364
    SW: 1037369819
    EDC16U1 Audi A3 2.0TDI
    mod egr off.zip
  16. #149
    imcumen's Avatar
    Feb 2009
    FRANCE
    Hello
    THX
    Regards
    please i need remove only dtc p0135
    Regards
  17. #150
    Nov 2011
    Garage...
    Quote Originally Posted by blazej1200 View Post
    p0400 disabled
    wont work same error
