I cannot upgrade my VVDI-Prog, when I connect, it is red Dot and yellow flashing. When I go to upgrade, then it's only red light...and cannot find device.
keyantic (28th January, 2016)
VVDI PROG latest version V4.3.1 update
v4.3.1 (2016-01-27)
* This version DON't need update firmware
+ Add MC9S12GN16_UNSECURED,MC9S12GNA16_UNSECURED,
MC9S12GN32_UNSECURED,MC9S12GNA32_UNSECURED,
MC9S12G48_UNSECURED,MC9S12GA48_UNSECURED,
MC9S12GN48_UNSECURED,MC9S12G64_UNSECURED,
MC9S12GA64_UNSECURED,MC9S12G96_UNSECURED,
MC9S12GA96_UNSECURED,MC9S12G128_UNSECURED,
MC9S12GA128_UNSECURED,MC9S12G192_UNSECURED,
MC9S12GA192_UNSECURED,MC9S12G240_UNSECURED,
MC9S12GA240_UNSECURED optionsMask (0N95B,0N51A,0N75C,1N75C,0N48A,1N48A)
MC9S12HA32_UNSECURED,MC9S12HA48_UNSECURED,
MC9S12HA64_UNSECURED,MC9S12HY32_UNSECURED,
MC9S12HY48_UNSECURED,MC9S12HY64_UNSECURED optionsMask (0M34S)
MC9S12P32_UNSECURED,MC9S12P64_UNSECURED,
MC9S12P96_UNSECURED,MC9S12P128_UNSECURED options Mask (0M01N)
MC9S12XEA128_UNSECURED,MC9S12XEG128_UNSECURED,
MC9S12XEA128_SECURED,MC9S12XEG128_SECURED options Mask (1M53J,2M53J,0N36H,1N36H)
MC9S12XHY128_UNSECURED,MC9S12XHY256_UNSECURED optionsMask (0M23Y)
MC9S12XS64_UNSECURED,MC9S12XS128_UNSECURED,
MC9S12XS256_UNSECURED options Mask(0M04M,1M04M,0M05M)in <2-MCU>-><MOTOROLA>
+ Add MC9S12XE_UNLOCK option in <2-MCU>-><MOTOROLA>(Backup all data before use it)
+ Add ME20U2-XET256-BACKUP,ME20U2-XET512-BACKUP,MT22-XEP768-BACKUP,
MT60-XEP768-BACKUP options in <3-ECU>-><DELPHI>
+ Add the 12V power adaptor status in information dialog
ahl (28th January, 2016), diagprog7 (28th January, 2016), filutek (30th January, 2016), Key Center (28th January, 2016), keyantic (28th January, 2016)
Notes:Because of Chinese Traditional Spring Festival,mostly company will have a vacation from 3rd-13th,February,2016 in china.
in this period worker all not in company,about repair device or other issues should be waiting for the vacation end.
if User have any problem can post here,after back we will check and solve as soon as possible.
Still no update for pcf7945 bmw 868 keys...
Professional BMW immo solutions
Macedonia is one and GREEK!!!
totalkey (29th January, 2016)
I have connection with VVDI Prog...but it fails to update repeatedly. Any ideas? It hangs up during the "connecting to server" phase.
Also I am trying to read CAS 2 - and repeatedly fails to crack. Has anyone read this successfully with VVDI Prog?
VVdi doesn't want to be defined in the program
on win10
on win xp everything is good
I've connected the in-circuit cable to a 868 BMW key board which looks exactly the same as in the VVDI software picture. I've checked the connections a few times and they are fine.
I've also checked de pcf79xx adaptor and it's the latest version, with a 0 ohm in R19 resistor.
My OS is windows 7 and I've selected PCF7945 - IN CIRCUIT option in the VVDI software.
When I try to read the eeprom I always get the same error:
- Read (0%)
- Read error
I've tryed a few times with and without the soldered battery of the keyfob.
Do you have any suggestions? Someone have readed the eeprom correctly?
Thanks in advance!![]()
you won't be able to read it.Only option to read it is reset security and read it.
But this will erase content.
mickye_dj (19th October, 2017)
Thank you bearheroes,
Yes, when I reset the security I can read it. But when VVDI renew the mcu, it also protects its contents and that's why I can't read the Eeprom.
Is this tool safe for cash 5m48h? Or is it very risky
Don't forget to hit thanks button
