Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 49
  1. #16
    Feb 2010
    Only year 2000 goes via obd and have round connector under the hood. 2001 and up you need to take out dash and do 35080.
  2. #17
    Jan 2017
    Only dash or LCM to?
  3. #18
    Apr 2010
    Gdansk Poland
    If you have new dasch and old lcm and ews then you need modify only dasch. You need open dasch and read eprom. I think pasoft 1,4 can modify vin in dach by obd but km must modify directly in chip.
  4. #19
    Jan 2017
    I only have Digiprog 3.
    also have a used LCM inside, because old one was broken
  5. #20
    Oct 2010
    Well to start off with do, dash 35080 chip, DP3 will handle that chip fine, LCM you can do using obd after
  6. #21
    May 2010
    Poland
    Default BMW e46 Digiprog 3
    In this case for you is better to use x-prog. 3 in 1. Manual-pinout, km, vin.
    10min. and done.
    Wysłane z iPhone za pomocą Tapatalk
  7. #22
    Jan 2017
    Never heard of xprog. Send me link pls
  8. #23
    May 2010
    Poland
    http://www.eldb.eu/index.php?route=p...tegory&path=35
  9. #24
    Jan 2017
    Cant i change vin over eeprom with Digiprog?!
  10. #25
    Oct 2015
    Quote Originally Posted by zix1 View Post
    Yes you can !
    If I help you don't forget thanks button
  11. The Following User Says Thank You to memet99600 For This Useful Post:
    zix1 (10th February, 2017)
  12. #26
    Jan 2017
    Im failing to find a hexa calculator where i can manually fill in the code
  13. #27
    captain crackers's Avatar
    Jun 2010
    england
    You need an ascii to hex calculator. As a clue 31 hex = 1 ascii, 32 hex = 2 ascii etc. Arthur.
  14. #28
    Jan 2017
    Yeah im failing to find one where im able manually type in the code
  15. #29
    Alawigmx's Avatar
    Aug 2016
    Sweden
    Ive only done E46's using Digimaster, just removing cluster and LCM, clearing/resetting LCM, then read/adjust mileage 35080 erase and then finally write. Works flawlessly, I mostly use Digiprog for OBD odometers in VAG cars.
  16. #30
    Apr 2010
    Gdansk Poland
    lcm you can adjust with passoft 1,4 by obd.
