I try many time not success it have error cpu not connect
will try again today
thank
have error
[2018-03-29 19:13:12] : Change to 2-MCU-->RENESAS-R8C-->R5F21548G
[2018-03-29 19:13:14] : Select <D-FLASH>
[2018-03-29 19:13:22] : Select <D-FLASH>
[2018-03-29 19:13:29] : Check Device...
[2018-03-29 19:13:30] : 12V Power Adaptor connected
[2018-03-29 19:13:30] : Initialization device...
[2018-03-29 19:13:32] : Initialization success!
[2018-03-29 19:13:33] : Initialization chip...
[2018-03-29 19:13:35] : Try Security Bytes 00000000000000
[2018-03-29 19:13:35] : Security pass success
[2018-03-29 19:13:35] : Start communication...
[2018-03-29 19:13:35] : Read length:0x1000
[2018-03-29 19:13:35] : Reading...(0%)
[2018-03-29 19:13:35] : Read Error
try Erase no problem
2018-03-29 20:25:34] : User select yes
[2018-03-29 20:25:34] : Check Device...
[2018-03-29 20:25:36] : 12V Power Adaptor connected
[2018-03-29 20:25:36] : Initialization device...
[2018-03-29 20:25:36] : Initialization success!
[2018-03-29 20:25:37] : Initialization chip...
[2018-03-29 20:25:38] : Try Security Bytes 00000000000000
[2018-03-29 20:25:38] : Security pass success
[2018-03-29 20:25:38] : Start communication...
[2018-03-29 20:25:38] : Erase length:0x1000
[2018-03-29 20:25:38] : Erasing...(0%)
[2018-03-29 20:25:38] : Erasing...(25%)
[2018-03-29 20:25:38] : Erasing...(50%)
[2018-03-29 20:25:38] : Erasing...(75%)
[2018-03-29 20:25:39] : Erasing...(100%)
[2018-03-29 20:25:39] : End communication...
[2018-03-29 20:25:39] : Operation success
And try write it no problem
[2018-03-29 20:27:04] : Start communication...
[2018-03-29 20:27:04] : User select yes
[2018-03-29 20:27:04] : Erase length:0x1000
[2018-03-29 20:27:04] : Erasing...(0%)
[2018-03-29 20:27:04] : Erasing...(25%)
[2018-03-29 20:27:04] : Erasing...(50%)
[2018-03-29 20:27:04] : Erasing...(75%)
[2018-03-29 20:27:04] : Erasing...(100%)
[2018-03-29 20:27:04] : Write length:0x1000
[2018-03-29 20:27:04] : Writting...(0%)
[2018-03-29 20:27:05] : Writting...(25%)
[2018-03-29 20:27:05] : Writting...(50%)
[2018-03-29 20:27:05] : Writting...(75%)
[2018-03-29 20:27:05] : Writting...(100%)
[2018-03-29 20:27:05] : End communication...
[2018-03-29 20:27:05] : Operation success
have solution?
thank
Hi for MCU R5F21548G I try use other tool erase full chip. VVDIPROG can read and write normaly
But if in the MCU have data inside . VVDIPROG can't connect . I try connet with 1 wire MODE with other tool . can write no prblem.
Can you make 1 wire Mode?
thank
