Page 120 of 295 FirstFirst ... 2070110115116117118119120121122123124125130170220 ... LastLast
Results 1,786 to 1,800 of 4423
Thread: VVDI PROG
  1. #1786
    Nov 2012
    The question is wrong .
    The real one is : Is there anything safe for cas 4 an cas 4 + ?
    I have a good friend that made about 4 5m48h, and he sayd that it is ok.
    But otherwise, I have not tried.
  2. #1787
    sniegavirs's Avatar
    Mar 2017
    Latvia
    I am asking for VVDI Prog abilities with CAS4 because this thread is about VVDI Prog.
    Quote Originally Posted by dorofteius View Post
  3. #1788
    kevfield's Avatar
    Aug 2009
    uk
    I think you will find that there's no tool 100% safe to read the mcu your talking about , the best way of putting it would be whats the programmer that is the most successful at reading correct !!
    Thanks Kev
  4. #1789
    Nov 2012
    So . What did I spell wrong ?
    There is no safe way. And that is it.
    That includes the programmer that we are talking about.
  5. #1790
    sniegavirs's Avatar
    Mar 2017
    Latvia
    OK, i will ask differently...
    Does anybody have had any problems with CAS4 mask: 5M48H and 1N35H reading and writing with VVDI Prog???
  6. #1791
    May 2010
    Poland
    Yes, I had. When you crack mcu I recomend use hot air. I wrote about it.
    Sent from iOS
  7. The Following User Says Thank You to eagleone-two For This Useful Post:
    sniegavirs (7th December, 2017)
  8. #1792
    Top Poster sbtriny's Avatar
    Sep 2010
    Quote Originally Posted by sniegavirs View Post
    So how safe is CAS4 mask: 5M48H and 1N35H reading and writing!? Anyone have experience with this!?
    Hi, m8.
    I have vvdi prog and use to read for all 9s12 mcu.
    It's all success to read cas4 and cas4+ ( mask 5m48h and 1n35h )
    Recommand for 9s12
    But, don't recommand hc12 and 908.
    나의 LG-F500L 의 Tapatalk에서 보냄
    thank you, all my friends.
  9. The Following User Says Thank You to sbtriny For This Useful Post:
    sniegavirs (8th December, 2017)
  10. #1793
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by sbtriny View Post
    Hi, m8.
    Recommand for 9s12
    what you have for problem with HC908 ? i read this mcu very well everytime success
    many thanks to friend kevfield
  11. #1794
    Feb 2012
    i have this adapter i tested it on 350806 , it doesnt work 4.6.5
  12. #1795
    Sep 2016
    I've read CAS 2, CAS 3 and CAS 4 with VVDI Prog.
    All work good both EEPROM and Flash
  13. #1796
    Griunvaldas's Avatar
    Aug 2010
    DC-DC
    I tried BMW CAS4 5M48H - can not read!
    I tried Audi MED17.1 ECU tricore - can not read! (Can not crack MCU password)
    I tried to reset PCF7945 - can not reset (leaves three areas that can not rewrite)
    Only thing that worked is HC08 for mercedes EZS (50/50 one time read OK, other erased flash)
    Having original xprogM and Orange5 I dont use this one much, but everytime I try to use for a quick solution it fails...
  14. The Following User Says Thank You to Griunvaldas For This Useful Post:
  15. #1797
    Oct 2017
    BMW
    2 cas4 5M48 read backup is OK
  16. The Following User Says Thank You to TVO For This Useful Post:
  17. #1798
    I also read 2 cas 4 one for testing and the other to make key and both success from first time
  18. The Following 2 Users Say Thank You to tech111 For This Useful Post:
    habbyb (9th December, 2017), sniegavirs (8th December, 2017)
  19. #1799
    claudio35's Avatar
    Dec 2009
    Chile
    Dash mini cooper, 9s12dg128 sec, no work, no success very bad tool, r260 working fast very well
  20. #1800
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    Has anyone been successful in unlocking pcf7952 of a Nissan smart key? Have tried both chip and in circuit but it is still remains locked.
    Sent from my A718 Xplora Plus using Tapatalk
  21. The Following User Says Thank You to autocheck For This Useful Post:
    Griunvaldas (11th December, 2017)
