Results 1 to 12 of 12
Hybrid View
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Check engine to chassis ground cable... As mentioned use directly negative cable from battery to ecu...
    You have power at ecu pins?
  2. The Following User Says Thank You to Panathaole For This Useful Post:
    Nicolos (6th April, 2019)
  3. #2
    Member Nicolos's Avatar
    Aug 2018
    Belgium
    Quote Originally Posted by Panathaole View Post
    Problem solved!!!
    You were right.Ground cable was defect.No ground.
