Results 1 to 9 of 9
    Jun 2010
    Default MAC and CS PCR2.1
    Hi all,
    is it possible to have a MAC and CS from the flash and eeprom extracted with KTAG for a PCR2.1.
    Thank you beforhand.
    sorry for my English.
    Thank
    May 2010
    Europe
    This type of ECU is protected. Did you use KTag ori or clone?
    Jun 2010
    Hi, My ktag is clone. But i have already unlocked my ECU.
    I need the PIN/CS and MAC to adapt with my AVDI because i don't have the AN057 licence in order to extract them
    May 2017
    Cant be done such with SSM... cant, because need fullflash for MAC, CS or MCU ID.
    So pcm flash is cheapest solution for. Other tools autotuner, magic motorsport, UDHS ...
    rafal's Avatar
    Jul 2010
    UK - PL
    You must have the Full Flash or CPU serial number from PRC2.1. The CPU Serial number can show You devices Like PolDiag(OVDT OBD Interface), MagPro, VagCanPro, PCMFlasher, MPPSv23(orig). Or You need to read the FULL Flah in BSL mode. The K-Tag, KESS and Galetto v54 can't read the FULL flash and show CPU SN.
    need help
    now my goal is to buy xp-005
    who will help?
    Jun 2010
    Thank you for quick responses.
    I will try to find another solution in the one that you proposed to me.
    Thanks again.
    Jun 2010
    hi, sorry i still have a question. can we get the info from ecu with ODIS-E.
    Thanks.
    May 2010
    Europe
    Quote Originally Posted by gege52 View Post
    Thanks.
    No, but if you have ODIS on-line service you can make this job perfect.
    Attention ! donor ECU don't come by theft database.
    Good luck!
    ricked's Avatar
    Apr 2016
    Europe
    i can confirm that PIN/CS and MAC can not be extracted from the flash file that is posted in first post
