Hello, is there anyone able to permanently eliminate the noise of the 1.6 TDI CR injectors?
I am attaching the file of a Golf 6 with pcr2.1
Thank you
Thank you
Downgrade sw before diesel gate or your injectors are in bad condition
redonerj (10th December, 2021)
What does it mean download before diesel gate!!
Sent from my SM-A125F using Tapatalk
On 1.6 you have to remove a valve on injectors pipes which it gets blocked always and you have to re-adapt with VCDS min. Fuel quantity and its done!
No injector noise anymore.
Autotuner Master - FLEX Master - DFOX Master (DFBtechnology) PCMflash 1.3.8 - VCDS hex v2 - Scanmatik 2 pro - Launch - Odis
"clones" -> Ktag - Kess v2 - Mpps v22 - FGtech - Inpa -
WinOLS 5
IF helped! Press "Rep & Thanks"!
fgperformance (10th December, 2021), sente5500 (7th June, 2024)
As you can see on the image .. where the unburned fuel gets back from injectors on the end of the pipe.. there is a plastic valve.. you have to remove that valve and connect the pipe again but without the valve!
You can adapt injectors minimum fuel quantity with VCDS - > engine -> enter security code -> and you will find to adaption list.
Please dont forget to press thanks and rep!
WinOLS 5
Do i need to downgrade sw or just remove those plastics from its place and make adjustment of injector needle in sw with vcds
No need any downgrade
Just find the proper valve .. remove it , connect pipe and do with vcds
The adaption time will take around 10 minutes and after that just drive a bit and u will no hear any noise anymore!
I have fixed too many like that.
WinOLS 5
This solution its just for 1.6 or and for another types of vag engines
For 1.6 tdi only.
WinOLS 5
ASCM (21st November, 2021)
Which valve need to remove ?
Is it clear now?
WinOLS 5
ASCM (21st November, 2021), autocentarvu (21st March, 2023), sludoworm (3rd April, 2025)
Yes its clear now how many valves are there? for what its is this valve its for retention of return fuel pressure or anything else
