ukash (3rd February, 2022)
Cześć!
Potrzebuję etapu 1 sw1037384336 hw0281012868
Dzięki!
Can anyone make me a good Stage 1 for my C205 / W205
I might very soon inherit of a 98 Golf GTI 1.8T, however it has a 06A906018R ECU instead of the more common 06A906018CG.
Is there a stage 1 available for this 06A906018R ECU ?
I can find two software version: 358109 and 359591, are they compatible ? The files avec very different…
parasitfr (10th May, 2023)
Hey Guys,
Does anyone have a stage 1 for 074906021L (MSA15.5) 2.5TDI ACV T4?
I attach original file.
Thanks in advance!![]()
audi 2.5 tdi ake engine . please stage 1 if possible
Follow-up, replying to myself.
So after a few days of digging, I found a stage 1 for a 06A906018CG on this forum and by comparing with the original file I was able to list all maps modifications.
I then found the matching tables in the original files for 06A906018R 358109 and 359591 and made the same modification. Then using WinOLS 2.24 I corrected the checksum.
As soon as I get the car I will report back. Anyone willing to try is welcome to report back too.
The question remains as to what the difference between 06A906018R 358109 and 359591 is ?
Edit : Stage 1 files have 150hp in the name but it’s probably more like 190hp/300Nm…
trt2020 (24th February, 2022)
Can anyone make me a stage 1 or slightly more with pop and bangs please?
audi A3 2.0 tfsi axx
jamiewilliams93 (8th February, 2022)
Hi, Please can someone send me original map? BMW e60 530xd 170kw 2006. thank you
Hey, i record twice and read twice after recording there is some CHANGES in the file if i read it after writing it!
Is it normal?
REPHRASE, after writing your file i read it from ECU and the file in ECU is different, is it OK for it to be a little different?
File that i see is attached below!
EDIT!
Write file to ECU as said above but THROTTLE BODY still moves when vehicle is warm but NOT hot, so after driving 5 minutes throttle body still closes but after driving 10 minutes i cannot see it moving anymore!
Hello.
I kindly request you to turn off the EGR and DPF.
If possible I would also like Stage 1.
Thank you
wezyk (9th February, 2022)
