@XTR Your keeplinks is an embarressment. Why do you use that crap ?
Free, without password, VIIPlusLoader 08.022.02
https://mega.nz/file/NFMVEaBY#gXz-9x...iAEsIwjoL_FadM
carpcat (29th March, 2022), DreamLand69 (28th March, 2022), liviudiaconu (28th March, 2022), miglins (11th April, 2022), rch11 (29th March, 2022), subzdarg (29th March, 2022), ZIPPO4594 (27th March, 2022)
Hello Guys
I have a big problem with my VCDS Hex-can clone Atmega 162 based.
The "Test" is correct, the interface is connect, but i have the
License Status: Revoked
I have tried with different versions of VCDS but the problem remains.
I was using the loader ver 1.15.1, now I have tried with the loader 9.2 but I have not solved the problem.
I tried to flash the eeprom in another language, same problem.
I have experience for flashing the interface.
Can you give me some advice to restore.
Greetings
Tks .....................
Mine is working just fine.
But, i installed VCDS with internet off and imediatly blocked internet access in firewall.
i’m using it almost every day without problems.
I done the exact same thing with the old loader and i was ocassionaly getting License Revoked.
Tried vcds new 22.3.1 with 9.2 loader, so far so good. Labels and UDS_EV update i suppose, compared to 22.3.0
miouser (6th April, 2022)
Hi all, i need your help I am newbie here..
I have VAG171 cable - inside is assembled Atmega162 + ATF16v88 + FTDI 1703-C
can you please point me to correct hexdumps for this HW?
kolimer loader v2 vcds 20.12
why do i get this error ? is cable going bad? tested on 2018 and 2011 same error
Internal ROD error:
Hi, I'm looking for a vcds with c-sniffer.
I'm currently using vcds 19.6.0 and I have a problem. When I try to enter 17 dashboard block (UDS), vcds crashes. No problem with other blocks (1 engine, 2 transmisstion CAN protocol).
Who is the developer of the c-sniffer utility? What versions of vcds does it work with?
VIIPlusLoader-08.022.04-FULL-Installer
https://mega.nz/file/DhdlgYxa#wcnePu...tboj5kgqIRi1x8
Achtuhr (12th April, 2022), AYD (12th April, 2022), darka7 (11th April, 2022), davy73 (14th April, 2022), jaselvd (18th April, 2022), kfz09 (12th April, 2022), liviudiaconu (11th April, 2022), miouser (11th April, 2022), mkii (17th April, 2022), rch11 (19th April, 2022), seal777 (22nd April, 2022), wiechec (12th April, 2022), Za589 (16th April, 2022), ZIPPO4594 (11th April, 2022)
Tested 08.022.04 and have a lot of bug's with 22.3.1 EN - sometimes licence revoked, interface not found, and the big big issue it's on Engine - Security Acces - 27971 - it is not working... (on the same car with the same software 22.3.1 EN but with Atmega162 interface it is working perfect)...the problem it is from VII PLus Loader. Also Tested with 21.9.0 ROJ sometimes licence revoked, sometimes interface nor found but the security acces on engine IT IS WORKING.
The last VII Plus Loader who work well foe me it is 08.021.13 with 21.9.0 EN and 21.9.0 ROJ.
PS. The Test Car It Is SKODA FABIA 2014 1.6TDI
I would like to see a response from our beloved FLY .
Maybe he can clarify why it is not working as it is supposed to be .........
Tomas003 (13th April, 2022)
