Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 34
  1. #16
    Mar 2014
    Quote Originally Posted by totalkey View Post
    You need 8a42, try again with this code
    Thank you for advice. Will try tomorrow.
  2. #17
    Mar 2014
    When I added new transponder I used Pin Code 8A62, but new remote didn't synchronized with the car. Only one the 1st remote still in the system.
    New ones can't added. Why new transponder added with pin code 8A62 and new remote didn't ?
  3. The Following User Says Thank You to vitimax For This Useful Post:
    p1et (11th October, 2024)
  4. #18
    Apr 2010
    This is separate remote and transponder, you need precoded transporder and manual program remote
    Sent from my VOYAGER2_DG310 using Tapatalk
  5. #19
    Mar 2014
    I used original key 6370A159, that was already precoded. I program old and new keys into the car, but couldn't program remote.
    I used FVDI tools and X100 Pro tool and both tools didn't add remote to the car. Only old remote still works.
    Maybe these tools can't do this procedure ?
  6. #20
    Apr 2010
    Quote Originally Posted by vitimax View Post
    There is manually way to do it, search Google, or here
  7. #21
    Mar 2014
    No way to do that manually. Only some special tool can do it.
    If you can recommend me manual instruction, I'll be very thankful and grateful.
  8. #22
    Apr 2010
    Basically I do this years by obd, gscan or avdi, but you.can try connect to immo with scan tool or x100 than push on off hazard button 7 times than push remote button, take a look in Google because I can't answer all your questions
  9. The Following User Says Thank You to totalkey For This Useful Post:
    vitimax (25th June, 2016)
  10. #23
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    Seemed to have trouble doing one today - tried avdi and manually. guess need better tools
    I am a FUD
  11. #24
    castin's Avatar
    Oct 2015
    Poland
    Mitsubishi Eclipse 2007 - obd2 pin 1 to ground and 4(?) times on/off hazard button, then push button on remote and ok. Search on google. Meybe work.
  12. #25
    Oct 2017
    Zed Full works 1st time every time I have done this remote.
    I did once on skp900, but it took half an hour, and only worked once I disconnected the device, then reconnected and tried again.
    Definitely separate remote and chip.
    It was the "hold lock and unlock for 3 flashes, then lock or unlock for 1 flash.
    All done on KD. The one I did on skp900 came back 2 months later and stopped working, re did it on ZF and hasn't come back since.
    And all remotes are deleted when you need to add 1
    Sent from my SM-G935F using Tapatalk
  13. #26
    Mar 2018
    Knowing Mitsu, its probably a manual procedure for remote. Proxy should be automatic when you program the key
  14. #27
    p1et's Avatar
    Oct 2013
    Is there any other tool apart from avdi and zedfull which can program remote to ASX? I tried Smart Pro, Lonsdor, Key Tool Plus without luck.
    Anyone actually tried manual procedure? Doubt it work for that model year but maybe?
  15. #28
    Mar 2018
    UK
    Quote Originally Posted by p1et View Post
    Few days ago I programmed ASX 2015 with Autel
    I'm pretty sure that AVDI also can program it and also the other tools that you have so maybe you have wrong key or faulty car
  16. The Following User Says Thank You to Manta1600 For This Useful Post:
    p1et (14th October, 2024)
  17. #29
    Aug 2009
    Bulgaria
    Did lancer 2008ish with avdi, and 2 ASXs with autel.
    Lancer and one ASX aftermarket keys, and one ASX with universal remote and both avdi and autel programmed the remotes.
  18. The Following User Says Thank You to amm For This Useful Post:
  19. #30
    fuzz1's Avatar
    Jul 2019
    Are the keys from the lancer cs not the same as the asx? I think they are both omron keys with the chip separate in the remote.
