Results 1 to 14 of 14
    Jan 2018
    Default OPEL CORSA D IMMO FAULT
    Hello, I have a 2008 Opel Corsa D with an immobilizer problem. I have the PIN code tested on OPCOM. I have two fault codes on the engine control unit: P1632 and P1679.
    ECU: BOSCH ME7.6.2
    BCM: DELPHI.
    I need the BCM+ ECU and Dash CAN connection.
    Or if someone can perform an immo off on the ECU, or virgin state
    Thanks in advance.
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Do you have environment identifier error in other modules?
    Jan 2018
    YES with IPC SMD
    DIS KO NO COMM
    foxtec800's Avatar
    Jan 2010
    reset bcm with tech2 or similar and reprogram,, its a known issue due to battery voltage
    May 2017
    You solve also with OPCOM, reset BCM, ECU IPC and reprogram....
    Faraday's Avatar
    May 2012
    Quote Originally Posted by carmoh View Post
    YES with IPC SMD
    DIS KO NO COMM
    USE Tech2 it will guide you by hand.
    Bllinda's Avatar
    May 2010
    Baltic
    ECU: BOSCH ME7.6.2
    BCM: DELPHI.
    Thanks in advance.
    You need to read mcunec
    Quote Originally Posted by foxtec800 View Post
    Quote Originally Posted by ginodilegno10 View Post
    Quote Originally Posted by Faraday View Post
    They are all right
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
    Mar 2018
    UK
    Quote Originally Posted by Bllinda View Post
    Autel read the BCM pin by OBD
    Bllinda's Avatar
    May 2010
    Baltic
    Quote Originally Posted by Manta1600 View Post
    And what will you do if MW93C86 and MCUnec are different crypts?
    today
    Mar 2018
    UK
    I never checked what is inside as always when I needed to read the pin from BCM by OBD was successful
    Also as the BCM belong to this car you can read the pin from few other modules
  11. #11
    Jan 2018
    Hi my op com china clone havn't option to reset IPC only bcm and ecu
  12. #12
    Bllinda's Avatar
    May 2010
    Baltic
    You need to go to the dtc.
    Power – Wrong Transponder Key
    P – Wrong Environment Identifier Received BCM_(BodyControlModule)
    today
  13. #13
    Mar 2018
    UK
    And what ???
    You can have this code in 2 situation
    1st - when someone already reseted the BCM and left it not programed
    2nd - Someone fitted BCM from different car
    If the Autel can't read the pin by OBD I will read it on bench or I will supply BCM that can be read by OBD from the scrapyard
  14. #14
    Bllinda's Avatar
    May 2010
    Baltic
    The story is endless and it will be charitable
    2nd - Someone fitted BCM from different car mw-c86
    today
  15. The Following 2 Users Say Thank You to Bllinda For This Useful Post:
    Manta1600 (27th April, 2025), Saab A Dalys LT (28th April, 2025)
