Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Feb 2010
    Default Opel Immo Code from REC
    Quote Originally Posted by obdmaster View Post
    Just had success with Nasratech opel pin reader on 2004 meriva Z16XE.
    Nasratech have also sent me list of models covered and working at the moment its attached to thread.
    Hello guys!
    I bought from e-bay REC module, but I don't have pin code and can't reprogram for my immo code VIN number etc.
    Can help anyone?
    Best Regards!
    puiu's Avatar
    Timisoara
    Quote Originally Posted by Dreamexplorer View Post
    Hello guys!
    Can help anyone?
    Best Regards!
    Read eeprom inside,post dump ,and for shure someone will give you the pin
    regards
    Puiu
    drakov's Avatar
    Aug 2008
    Moved to Immo Section
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    Feb 2010
    Quote Originally Posted by puiu View Post
    regards
    Puiu
    Inside in the REC module has MB90548GHDS micro controller
    ( http://www.datasheetcatalog.org/data...6/763937_1.pdf)
    and near the controller seat 950403 IC
    You think the 950403 is a 95040 SPI EEPROM?
    (http://pdf1.alldatasheet.com/datashe...95040-BN3.html)
    It is possible to read out by OBD? Or I have to desolder it and use willepro?
    Best Regards!
    Feb 2010
    (M95040-BN3 pdf, M95040-BN3 description, M95040-BN3 datasheets, M95040-BN3 view ::: ALLDATASHEET :::)
    Best Regards!
    Hello guys,
    Today I readed the 95040 from REC, but I don't see the immo pin in ASCII.
    Please help.
    Best Regards.
    Shmortz's Avatar
    Apr 2010
    in the middle of nowhere
    try 7177 or 7771 and post result
    Mar 2010
    Earth
    Hello guys,
    Please help.
    Best Regards.
    Your pin is 8442
    pls confirm
    Feb 2010
    Quote Originally Posted by autoenthu View Post
    Your pin is 8442
    pls confirm
    Thank You, I will try soon and reply the result.
    Best Regards!
    Jul 2010
    So, what is the result ?
    Feb 2010
    Default opel zafira B REC immo pin
    Hi guys,
    Sorry for late replay..
    I tried all the pins (7177, 7771, 8442), but the unit is rejected all.
    Someone has a good eeprom image with correct pin?
    Best Regards!
  11. #11
    Jan 2010
    Hi guys,
    Best Regards!
    even if you will enter correct PIN , will not work on the bench , only on the car !!!!!
  12. #12
    Dec 2009
    possible pin 9476 or 4606 but i don't sure sorry.
  13. #13
    Sep 2009
    try pin 7761
  14. #14
    Feb 2010
    Quote Originally Posted by janusz21 View Post
    try pin 7761
    HI, 7761 also wrong.
    Any idea?
  15. #15
    Sep 2009
    try pin 4847
