Try creating another profile Andy.
Page 62 of that tut sounds like your problem.
I know it's the same thing CK said to ya, but thats how they suggest to fix it.
Did exactly the same with the black 4.3 Wii and get different results.
Can play online but not multi player mode in Zombie mode.
Andy.
try uloader its a bit ugly but works really well http://www.digital-kaos.co.uk/forums...taller-143444/ and read post 37 from http://www.digital-kaos.co.uk/forums...78/index3.html you only need to install 224
Is this upgrade the same as the system upgrade from wii or does it just upgrade the shop channel
hey sorry i wasnt really reading along.
i kinda have the same problem.
just download the wii shop channel wad right?
hey guys,i installed the 2 wads,do i need to go to the shopping channel and update from there,as im still getting the update request online play or it just freezes on loading screen.3.3e neogamma.
Information about the Updates/Patches
The game will prompt you to download the update when you start Multiplayer. If you are already running the game at this time, switch to Single Player and restart Multiplayer to get it.
The update cannot be downloaded from Zombies, and you will be prompted to switch over to Multiplayer in order to access it. You must have a Wii Shop Channel account in order to download the update.
?You do not need an updated shop channel, you need to have used the channel at least once in the past.
?If you have never used the shop channel you can access and accept the user agreement in Wii Options - Wii Settings - Internet - User Agreements - YES - NEXT - Connecting to Internet - ACCEPT (If you accept the agreement) Back to the Wii Menu? - OK
?If you want you can update your shop channel here.
?The first update takes 60 blocks - When finished downloading you will be taken back to the multiplayer main menu. It will change to "Black Ops Online". The second and third update do not require a download. The forth update takes zero blocks and a download is required.
?The first and forth update are in the form of a save file. "Call of duty pay and play" = 59 blocks
?Yes you can accept the update from the backup of your original disc.
?If you don't get the update prompt or you get the "no content available or purchase or re-download" message, It's because you somehow have the wrong region game. You need the game region to match your Wiis region.
?If you have the correct region game for your console and you have a region changed Wii then you will not get the update prompt. Do this....
ok,ive never used the shopping channel so ive got to ok the shop channel and connect24 user agreement in settings and try again
cheerz ck,its working now,accepted agreement,turned off conect24,started shop channel,then started black ops,completed update,zombies works aswell,thanx again ck
thank you for this. I couldn't figure out how to get the shop to work on 4.2U.
