Page 5 of 14 FirstFirst 12345678910 ... LastLast
Results 61 to 75 of 196
  1. #61
    puiu's Avatar
    Timisoara
  2. #62
    Feb 2010
    Default SAAB card
    Here's the Saab bin, maybe anyone needs it.
  3. The Following 6 Users Say Thank You to hashwood For This Useful Post:
    AdrianCR (5th July, 2019), kamaleon (22nd March, 2018), kreepyme (3rd December, 2021), shanektm450 (7th August, 2020), Silver740 (29th April, 2019), smart keys (22nd May, 2013)
  4. #63
    Dec 2009
    you can pass me the rar password please GM tech2
  5. #64
    Jul 2010
    Is there any way update my older Tech 2 . i bought the scanner on 1996 year . should i buy the 32mb PCMI card for flash programmer or just i flash the software u offered below into my older card ? anybody help me / thanks
  6. #65
    Jul 2010
    Default The password of .rar
    Quote Originally Posted by alexG View Post
    Sorry my frends .
    For SUZUKI - 01.240.022 (1996-2008)10MB.rar
    Pas: SUZUKI
    For card ezplorer Pass: card explorer3.21
    May i know the password for GM Tech 2 1996-2010 29[1][1].006 North American 32mb CH.rar
  7. #66
    Junior Member Fahrer's Avatar
    Sweden
    Default Write protected card
    Hello guys!
    I just bought a chinese clone Tech2 with a preinstalled 32mb PCMCIA with GM software.
    I would like to put Saab v145 software on the card.
    Downloaded and installed the MCE software and the card reads out fine (Manual card detect), but when it comes to erasing/writing, I have not found any setting that works.
    When I choose autodetect card, it sais "Failed to auto-identify the CARD type. Make sure the CARD write protect switch is off"
    The problem is that the card doesen?t have a physical switch.
    Does any of you encountered similar problems?
  8. #67
    DK Veteran ibmman's Avatar
    Jul 2009
    Living Hell
    Quote Originally Posted by Fahrer View Post
    Hello guys!
    I don't know about aftermarket cards. Myfactory cards have a switch in the end of the card. Also my cards have to be written with 12 volts. They can read the card but not write back to them. Most newer laptops can't do this. I use an old Dell Latitude.
  9. #68
    Sweden
    I use a Dell Latitude D610 during my tries.
    Pretty old stuff, but maybe not old enough to have a 12V PCMCIA.
    BTW
    The Tech2 also states the card is in write protect during initialization, but no switch to be found on the PCMCIA card.
  10. #69
    Feb 2010
    I use a dell d610 and writes fine.. my clone card and genuine card both have switches in the end... although i do ind that the genuine card works better for Holden software but the non genuine for the US based software
  11. #70
    Dec 2010
    vietnam
    Try
    password please!!! Thanks.
  12. #71
    alexG's Avatar
    Jun 2009
    Default Tech 2 GM - US NAO 30.004 1991-2011 .
    Pass : Tech 2 GM - US NAO 30.004 1991-2011
    Try it .
    For Tech 2 GM - US NAO 30.004 1991-2011
  13. #72
    Aug 2009
    When I run MCE I have this error message and it quits after I click OK. No matter what parameter I change.
    Master Computer Engineer, A+, Network+, MCP 4/2k/2k3, MCSA/MCSE 2k/2k3, MCTS, MCITP Enterprise Administrator, Microsoft Certified Trainer/Systems Engineer, Brainbench, ICDL and starting Ph.D.
  14. #73
    Jul 2009
    Living Hell
    Quote Originally Posted by alex1986 View Post
    You have 2 have the blue 32mb card to update to the latest software. The older black card is 10mb and doesn't have enough space for the new software bin file.
  15. #74
    May 2010
    Default 12 volt linear flash pcmcia card
    Quote Originally Posted by rrob311 View Post
    I have an old Sony Vaio pcg fxa-47 circa 1999 and it works. Both my cf48 pan. toughbooks do not work.
    Any laptop or pc can work as long as it has a pcmcia slot. I use Cardware Magik by Apsoft. It makes another boot profile and sets up the pci bus to write 12 volt cards. Ive set up many and all work well!! For both Mastertech and Tech 2 needs. I know Im late on info, hope I helped!
  16. #75
    Aug 2009
    When I update it, will it be a time limit?
