Problem with original Upa failing to read MC68H05l28.
  • Naphoomkrit
    • Dec 2024
    Hi.
    Having problem with original Upa failing to read MC68H05l28 (mazda b2500 instrument cluster)
    UPA-USB-UUprogs V-2.2 program test connection and voltmeter all pins read ok.
    But when I want to read mcu doesn't respond "Displays device not respond "
    Any Solution , kindly help
    https://img5.pic.in.th/file/secure-s...5ed5df20c6.jpg
    https://img2.pic.in.th/pic/5824d726-...6b93b4f3a7.jpg
    https://img5.pic.in.th/file/secure-s...b66bb348d3.jpg
    https://img2.pic.in.th/pic/abeaa3ed-...77fa5884a3.jpg
    https://img5.pic.in.th/file/secure-s...c823e2b24.jpeg
  • sportzfy
    • Dec 2024
    This issue might be caused by a connection problem, incorrect pinout settings, or software compatibility. Ensure that the adapter is properly seated and all connections are secure. Verify that the programming settings match the specifications of the MC68H05L28 chip, such as voltage and clock settings. Also, check if your UPA programmer software is up-to-date. If the issue persists, using an alternative programmer or checking the chip for potential damage might help. Anyone else faced thissportzfyand found a solution?"
    • Naphoomkrit
      • Dec 2024
      Originally posted by sportzfy
      This issue might be caused by a connection problem, incorrect pinout settings, or software compatibility. Ensure that the adapter is properly seated and all connections are secure. Verify that the programming settings match the specifications of the MC68H05L28 chip, such as voltage and clock settings. Also, check if your UPA programmer software is up-to-date. If the issue persists, using an alternative programmer or checking the chip for potential damage might help. Anyone else faced this problem and found a solution?"
      hi. sportzfy
      I'm sure the voltage and clock settings connections are correct.
      Not sure if your UPA programmer software is up to date?
      I'll check and find the latest one.
      thank you very much
