Blackbox 888
  • worntilltorn
    • 6
    DM500 Blackbox 888
    Hi
    i'm from SG and i recently bought a blackbox 888. based on what i read, it's actually a DM500c right?
    it has recently stopped working for no reason and i'm wondering whether i need to flash it to get it to work again.
    it just isnt responding to the remote or the standby button. Any kind soul can help? or guide me along? i cant seem to find the s***hub keys as well..
    i'm sorry but i'm really new to this. Hope i can get some help.
    thanks!
  • SGDVB
    • 210
    If you are having outdated key, your box should still be responding to remote (i.e: channel switch) but you only get to see FTA channel or black screen on paid channels.
    If you box is not responding at all, try to reboot by power off & on again. If still not responding, RMA with your supplier, hardware issued.
    Originally posted by worntilltorn
    Hi
    thanks!
    • worntilltorn
      • 6
      i've tried to reboot a couple of times..but there isnt any response..
      is there any other way?the light just remains on..
      • DreamersDVB
        • 245
        last try
        One last try,flash the box using dreamup with working image.If no response! Than i m certain hardware problem..sent back to supplier for repair.
        • SGDVB
          • 210
          What about pressing the standby button (next to IR receiver) on the box? Does it turn red?
          If it does not, guess no one here can help as this is hardware issue.
          Since you just got the box, believe there should be some form of warranty.
          Just checking, this box is ordered online & from which supplier?
          • worntilltorn
            • 6
            can i flash with an ethernet cable?standby button also doesnt work..it seems totally dead..
            the box is local actually and i'm trying to find the supplier as it got it off a friend..
            • SGDVB
              • 210
              You will also need a null modem cable in order to reflash using dreamup along with lan cable.
              Do not think you can flash your box using telnet method since your box hang.
              • worntilltorn
                • 6
                looks like there isnt much hope. gotta find a null modem cable then. it's just an adaptor or? probably have to find it from Sim lim square?
                • DBTraitor
                  • Feb 2011
                  • 616
                  go sim lim tower basement, lots of cables there
                  A wise man learn more from a foolish question than a fool can learn more from a wise answer.
                  • y2kpest
                    • 15
                    Hi, can anyone kind enough to advise me what's setup 4 digit numeric code? So far I'd tried (0000,1234,0937) but to no avail. Thanks.
                    • DreamersDVB
                      • 245
                      model
                      Whats your box model?
                      • y2kpest
                        • 15
                        Blackbox 888
                        • DreamersDVB
                          • 245
                          Blackbox 888 hmm the setup pin is set up by supplier,you need to ask him.If you cant get hold of him,download 500 image from download section here than make your own image.This solve your setup pin and Ftp pw problem.
                          Blackbox 888
                          • worntilltorn
                            • 6
                            Does anyone wanna sell their null modem cable?I can't find at Challenger and I'm lazy to go sim lim..
                            • y2kpest
                              • 15
                              Thanks. Hmmm...current now I'm having difficult in linking the box and the pc using a cross ethernet cable. Don't know is it ip address issue or the user login issue? Anyway I'm using DCC 2.95 to link up.
                              Any advise of linking it up? Thks.
