Blackbox 888
manually
For a start just use null modem cable for backup/flash.Untick the network box. It will take around 13min to complete.If you want fast than use lans cable from router than tick the network box,but still attach the null cable to rs232,it will complete under 3min.
try this procedure
Plug the USB-to-serial convertor cable into the a free USB port on the computer and install any software provided with the cable. A virtual serial port will be added to your computer, named "COM1" or similar, which appears to any software as a standard serial port. The serial port will be displayed under the "Ports" section of the Windows Device Manager.
Plug one end of the serial null modem cable into the end of the USB-to-serial converter. Power down the Dreambox and plug the other end of null modem cable into the nine pin serial socket on the back of the Dreambox, labeled "RS232." Power on the Dreambox.
3
Download the "Universal Dreamup" software available as a free download from the Dream Multimedia Web site. Open the file once it has downloaded and run the "DreamUP.exe" file to start the application.
4
Select the address of the virtual COM port provided by the USB-to-serial converter, using the drop down box next to the "Port" label in the "Universal DreamUP" application. Click the "Connect" button to allow the computer to connect to the Dreambox over the serial link. When the Dreambox is connected, you will see the message "Box attached and ready."
5
Download the DM500 firmware image from the Dream Multimedia Web site. Click the "Flash" button in the "DreamUP" application and select the DM500 firmware image which will have a ".img" extension. Click the "Open" button to start flashing the image. The flashing process will take several minutes and the software and box should be left undisturbed during the process. Once flashed, a dialog box will appear informing you the process is complete. Close the "DreamUP" application.
6
Unplug the null modem cable from the back of the Dreambox DM500. Power down the DM500 and leave turned off for 30 seconds. Power the unit back up and it should restart successfully using the new firmware.Comment
Additional point to note on your point 4.
When you click on "Connect" on dreamup, you box must be in power down (Off) mode. When click 'Coonect", you should have "Connection prepared, now switch on the dreambox!" then you power up or plug in the power port.
try this procedure
3
4
5
6
Not all people keep flashing their box. For me, I like to try out new firmware (i.e.: Pli-Jade, Nabilo & etc.) therefore will flash the box whenever there is new firmware to run test.
For you, I'll suggest you do a back-up of your working image & use it to re-flash if your box screw-up.
Other than that, will not suggest that you keep flashing the box.
i bought a usb to RS232 adaptor..but now i'm not sure if this is a null modem cable.
i cannot connect to my blackbox with this cable. did i get a wrong one?Comment
ftp
Have you ftp sg cable file to /temp folder.That file is at download section or use dreamboxedit..theres some post here how to do it.
Hope this help.
Ya I had already replace the cables.xml file into the box. I had also read the link you sent me, quite abstract. So can't catch any of it what is saying. The SH channel list is also hard to locate.Have you ftp sg cable file to /temp folder.That file is at download section or use dreamboxedit..theres some post here how to do it.
Hope this help.
PLi? Images website - PLi? Wiki: ChannelComment
