Guide: How to use FlashFXP to FTP to your Dreambox
  • motoheero
    • Jul 2010
    #136
    help!!!
    I am able to connect to my dreambox IP but couldnt log in after i keyed in "root" as the user name and "dreambox" as the password. Can anyone advise?
    • motoheero
      • Jul 2010
      #137
      Status: Connecting to 192.168.1.67:21...
      Status: Connection established, waiting for welcome message...
      Response: 220 VLC FTP Server
      Command: USER root
      Response: 331 Please specify the password.
      Command: PASS ********
      Response: 530 Login incorrect.
      Error: Critical error
      Error: Could not connect to server
      • keanu
        • Jul 2010
        • 5
        #138
        thanks for the detail explanation.
        i can't ftp to my dreambox. some connection error?! T.T
        server name: 192.xxxxxx
        user: root
        pass: dreambox
        port 80
        but it doesn't connect...
        • james12
          • Oct 2010
          • 20
          #139
          Big thanks to you thommo guest,am james12 i try your guide on how to flashfxp on dreambox500s,is good. And i connected flashfxp to my dreambox and it was connected to my dreambox ip address,but later it failed and the connection was losted, i try it several times,it keep on doing the samething.
          Please could you help me out.i will be glad to receive your response. Thanks
          • ministar
            • Nov 2010
            I've tried this for over 2 weeks. Nothing helps
            • adeshina500
              Can someone help on how to connect a dreambox to pc aand to internet.Pls i need a full explanation.Am just new in this business of dreambox installation.Av got some idea but not expert in the installation.
              • Lucky777
                • Feb 2011
                #142
                Great tutorial but I am having the same error as many others. I am able to see the contents of dreambox with my browser (Chrome) but am unable to connect using any FTP client.
                Seems like the password is not standard
                Msg from Filezilla:
                Status:	Connecting to 192.168.1.10:21...
                Response:	220 Welcome to the PLi dreambox FTP server
                Command:	USER root
                Both my PC and Dreambox connect to router. Anyone knows how else (ID/password) to connect?
                • z3nithx
                  • Sep 2011
                  • 8
                  #143
                  Mac users
                  Dear bros, been reading the guides. Very helpful indeed. However, I realize that all the instruction are for PC user. What about mac user? Is the software flashfxp the same? Or is there one for mac somewhere?
                  • Kidcreole
                    • Oct 2011
                    • 32
                    #144
                    Sorted! Green flashing light, Cooked power supply
                    • afcgunners
                      • Apr 2012
                      • 5
                      #145
                      hi i got problem as i have a fixed ip address, i can not connect to dream box via control center. Does the DB 800hd se work with Static Ip address if so how do i get the connection??
                      P.s the dreambox is connected to the router via WLAN, but fails at network test on ip address confirm??
                      • XeNo
                        • Sep 2012
                        • 6
                        #146
                        i'm new here, thx & appreciate for the guide. but juz one qns as i've been reading around from other threads. before flashing the box i need to backup the "keys" is the keys refer to the files in "var/keys" as stated in this guide?
                        find the ans to my qns already. thx~
                        • esakao
                          • Apr 2013
                          • 5
                          #147
                          Thank you. Will try tonight
                          • StoneFish
                            • May 2013
                            Hi I'm new here.
                            I using FlashFxp to Ftp my dreambox 500c but facing error during connecting.
                            Can someone help .Thanks
                            [R] Connecting to 192.168.1.1 -> IP=192.168.1.1 PORT=21 (attempt # 5)
                            [R] Connected to 192.168.1.1
                            [R] Connection failed (Connection closed by server)
                            [R] Delaying for 120 seconds before reconnect attempt #1
                            • chrispy1206
                              • Apr 2013
                              #149
                              All,
                              I am facing an issue, I was doing an update on my box and guess doing it wrong. So my box was not reacting at all.
                              I had to reinstall a new image plus bouquet for Sgp.
                              Issue now is that I do not have the required SCCE and keys for it.
                              I see all the channels in the list, but all locked.
                              Any advise where I can download it?
                              • Fir3b0t
                                • Aug 2013
                                thanks so much
