Guide: How to use FlashFXP to FTP to your Dreambox
  • smirnoff_rules
    • 8603
    #31
    we have the downloads here for the eurovox m8 .. do u know wot box it is . ie max . blue . red ~?
    • ColmF
      • 8
      #32
      I shall found out tomorrow. Thanks for your help. (I hope you don't mind me asking about a Eurovox on the dreambox forum. There doesn't seem to be a Eurovox forum).
      Colm
      • smirnoff_rules
        • 8603
        #33
        think its something we might need to add m8
        • smedzdave
          • 71
          #34
          I have a problem, i have tried connecting it to my pc but it doesnt seem to work, isit possible just to connect the modem cable to the dreambox then???
          Will it work??? if so is there anything else i need to do????
          • ema153
            • 9
            #35
            ema 153
            Thanks thommo
            For all the information you have given. But I Would like to know
            if i have to use a Ethernet cable or a SL 901 cable From my PC to the Dreambox once again manny thank's EMA.
            • smedzdave
              • 71
              #36
              Right i wonder if anyone can help me
              Im using my cable modem to connect to my Dreambox 7025 ok, so heres what i am doing,
              I am using a usb cable to conect my modem to my pc ( which is working)
              then i have put my ethernet cable from the modem to the Dreambox.
              Input the Ip address on the dreambox into the flashFXP
              Typed root in the username
              Typed dreambox into the Password
              Clicked Connect
              But it doesnt connect it says ''Connection Failed (Connection Timed Out)''
              So am i doing anything wrong??
              If So can someone please help me as i am now clueless as to what to do from here
              Much apreciated
              • ColmF
                • 8
                #37
                Ema,
                If you have a router (a broadband router) just connect an ethernet cable from your PC to your router, and once from your router to the dreambox.
                If you look at the first post on this thread it will tell you all you need to know. It did for me anyway
                Colm
                • smedzdave
                  • 71
                  #38
                  colmf would you be able to help me out mate???
                  • ColmF
                    • 8
                    #39
                    Semed,
                    Did you check the IP address on the dreambox itself first, and then input that into FXP?
                    I also disconnected my router from the internet first, to avoid confusion.
                    I note that you say you used your modem. Is this a broadband cable modem, or a broadband router? A cable modem will not do the job as it is not capable of making a network. It must be a router. (You use a router with DSL that you get over a telephone line. You use a modem with broadband that comes over your cable tv line).
                    _____________________________________
                    Guys,
                    Regarding my Eurovox query, I downloaded your files, got a friend to make me up a null modem cable, and called around to my father this eveing. I flased his Eurovox Max V, and it worked a charm! (I had to scan all the channels again.) It worked a charm! I now have one very happy daddy! I have left him this evening in a very good mood.
                    Thank you very much for your help! It is very much appreciated!
                    Colm
                    • pingg20
                      • 66
                      #40
                      the best info i have read i will certanly be trying it out when my other dreambox arrives from china its stuck at customs in coventry i sent for 2dreamboxes thinking they were coming from u.k. seller turned out to be from china only sent one initaly sending other now do you think customs may ask for duty on the box? never bought like this before the 1st box arrived without custom charges unfortunatly i think its faulty when you power on comes up press green button on setup wizard for tv settings wont respond to the remote also cant se any light on at the standby buttons any idea anybody thanks in advance
                      • aftermath
                        • 4345
                        #41
                        you might have had a bad flash m8, try re flashing again.
                        • deanofire
                          • 27
                          #42
                          sorry for being a dufuss Smirnof but where exactly at the top of the page is the fix ?
                          my eyes aint so good anymore ???
                          • pingg20
                            • 66
                            #43
                            cant get connection in flash fxp
                            hi i have changed the i.p. addresses as advised in string keeps coming up no route to host pc add 192.168.1.99 dreambox add 192.168.1.100 im useing crossover pach direct from pc dont know where im going wrong doing my head in any help would be great im useing the lead from my modem disconecting from the back of modem into dreambox therefore pc and box connected via crossover does that sound ok thanks in advance
                            • Dreamer
                              • 2020
                              #44
                              @Ping. R U sure it's a crossover ethernet(RJ45) cable and not just a standard one?
                              The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
                              • osborne82
                                Dreambox Guru
                                • 133
                                #45
                                you say ur using the lead from ur modem ? and pluging it into your dreambox if this is the case then theres ya problem as that would be a normal straight through ethernet cable and NOT crossover cable bud
                                ul need to use a proper crossover cable or go through a router and use the cable from your modem
                                cheers
                                osborne82
