I am well chuffed for you that my backed up 7025 imaged worked for you, did you have to re scan for channels? Please tell me what you had to do as I want to put that 7025 backup image image on this forum.
Your cable feed should go to tuner 1 in only. Then make a short lead, 6" or 8" that goes from tuner 1 out to tuner 2 in. Did your box not come with a short lead with 2 F connectors on it? This is used for this but you need the F converters to fit the cable connectors. Your cable feed should not go to the coax rf connector in the middle of the box, that is for aerial in and out so you can watch TV in another room
