How to JTAG a DM500
  • poupoul1313
    Hello,
    I have a dead DM500 and I need to get the Jtag procedure
    <--poupoul1313 added 1 Minutes and 32 Seconds later...-->
    Could someone post a simple and clear schema of the cabling of the damned JTAG ... Im desperated
    Many Thanks
    <--poupoul1313 added 1 Minutes and 18 Seconds later...-->
    Hello,
    Could it possible to publish the procedure for the Jtag
    I have no access .... to the download section
    • excal71
      #152
      Cable lengd
      Is it a Limit on Jtag Cable , how long can it be ? 5 Meters ?
      • KidDK
        • 4
        #153
        Want to try jtag myself. Dont know what to start from!
        <--KidDK added 1 Minutes and 49 Seconds later...-->
        About lenth of JTag cable, some post said not longer than 10 sm. Can it be true???
        • KidDK
          • 4
          #154
          Hello.
          Got my DM 500 killed this weekend. Did t know about this `Adios Amigo`. Now trying to get new one from my dealer. Thanks to danish law waranity works for 2 years! But just in case trying to know as much about JTAG.
          Want to know, after connection of JTAG isit DreamUp I have to use to burn the new boot?
          <--KidDK added 2 Minutes and 59 Seconds later...-->
          Is it possible to find out by using any software about you have clone or real one. The one I got was sold as real, but became a clone. And died th[ to Gemnini.
          <--KidDK added 2 Minutes and 2 Seconds later...-->
          If you got clone, is it possible to make gemnini think that it is a real one. Is any software alloud to fool gemnini?
          • aljondi
            hello,
            i hope it will work because it's my firsttime.
            <--aljondi added 10 Minutes and 20 Seconds later...-->
            it dosnt work ... what shoul i do to fix this issue?
            • Vilsa
              #156
              Hi,
              I have a problem. I have two Dreamboxes here (DM500). Unfortunatly they are fake and now I would like to rewrite the bootloader. With the DOSTool I was able to fix the sat-box but the cable box i wasnt able to program with the DOS Tool because I cant choose a cable boot loader from the drop down menue.
              Is there any opportunity to chose another bin file that the DOS Tool will write in it or is there any other DOS tool that is able choose extern bins to write into that flash? Unfortunatly the windows tool is not working here because i have the chip JS28F640 in the box.
              and as it seems you cannot programm that with the tool or is there maybe a crack existing for that?
              I have a CRS2 programmer here, that are able to write into the bootloader. I also have an Adapter unfortunatly I dont get a connection with that either maybe i would be able to write into the flash with that?
              • victorlcs
                • 5
                #157
                anyone tried gemini 4.40 ?
                • chopdre
                  • 6
                  #158
                  cant use dreamup
                  Hi, I've jtag the dm500c, but cant connect with dreamup, it's just waiting for acknowledgement and nothing happens.
                  Any idea to correct this problem.
                  Thanks in advance.
                  • alspa
                    Do NOT use Gemini 4.4, it has the same disable clone issue
                    Cheers,
                    Alspa
                    • gregobd
                      dm500s falsh the boot with jtag with CAS3
                      hi
                      all works fins but when i click on write the program quits and nothing happens ? any idea why is it doing that ?
                      • Devilfish
                        Administrator
                        • Feb 2008
                        • 7872
                        #161
                        Maybe try the DOS version.
                        • micromouse
                          • 162
                          #162
                          22222222222222222222222222222222
                          • lahore101
                            jtag
                            all team good work i apricated
                            • DonTon
                              • 9
                              #164
                              Hi gregobd
                              In the folder where the JtagWindows tool is located, do you have a blimg file there?
                              I experienced with this tool, when you click more the 4 times on connect, the tool crashed as well. So, I managed it as follow, start the JtagWindows tool, tryied 4 times, if the write button, wasn't enabled, close it and start the tool again (no joke).
                              Hope that helps
                              • micromouse
                                • 162
                                #165
